pebert 87 Posted March 28 Share Posted March 28 I have encountered an issue, my phone won't stay on fastboot mode, as soon as I send the first fastboot command (regardless if it's a "fastboot devices" or any other command the phone exits fastboot, shows the fxtec logo together with a small text in the upper left corner telling me that the any key will preform a reboot. Just pushing one of the volume buttona it reboots back to LOS. Any ideas on this? Quote Link to post Share on other sites
EskeRahn 4,420 Posted March 28 Share Posted March 28 10 hours ago, pebert said: I have encountered an issue, my phone won't stay on fastboot mode, as soon as I send the first fastboot command (regardless if it's a "fastboot devices" or any other command the phone exits fastboot, shows the fxtec logo together with a small text in the upper left corner telling me that the any key will preform a reboot. Just pushing one of the volume buttona it reboots back to LOS. Any ideas on this? The usual guesses would be PC, pc-usb-Port, Cable or port on the Pro1. After upgrade to new PC last fall never got flashing to work well, and fastboot acts oddly too. 1 Quote Link to post Share on other sites
pebert 87 Posted March 29 Share Posted March 29 That's so Microsoft, I guess a Windows phone doesn't have any issues. Will give it a try from my Linux machine instead, even though I'm sceptical that it will work, I'm running a Dell enterprise server, and that USB implementation/driver is a little bit "one of a kind" //Per 1 Quote Link to post Share on other sites
EskeRahn 4,420 Posted March 29 Share Posted March 29 If I fiddle using unsigned drivers, I can get things to work, but not with signed drivers. And oddly Google's own drivers were still unsigned, last I checked.... ADD: See also this 1 Quote Link to post Share on other sites
pebert 87 Posted March 29 Share Posted March 29 Interesting reading, Maybe the easiest way is to boot from my previous harddrive with windows 10 then. Quote Link to post Share on other sites
EskeRahn 4,420 Posted March 29 Share Posted March 29 5 hours ago, pebert said: Interesting reading, Maybe the easiest way is to boot from my previous harddrive with windows 10 then. Well at the least try that first, and if that works, you know the problem is at the PC side. Quote Link to post Share on other sites
pebert 87 Posted April 6 Share Posted April 6 Fastboot flashing procedure went flawless under win10. Unfortunately the phone got stuck in a boot loop, changed the active slot, but still didn't boot. Did a EDM flash instead, so now the phone boots up as it should on stock software. 1 Quote Link to post Share on other sites
