Pro1x call problems
hi,
I have some problems with calls.
When I try to call my phone I often get the voicemail
When I try to call with the phone, the call end immediately or i get "busy network"
The signal quality can be full or quite full in LTE or 3G
The problem is the same on Stock Android or LineageOS
My operator is "Free" in France
Any idea to fix that ?
ok i ll try that, thanks.
I found, if i set to "LTE only", there is no possibility to call, i can't find if the Pro1x is voLTE compatible ? i think, if "yes", it would be possible to make calls with "LTE only"
See this thread – the phone has some serious data and voice connectivity problems, mostly depending on which bands, most prominently LTE bands, your carrier uses:
Depending on that, there might be settings/workarounds or not. Unfortunately there is no general rule as to what works where.
(For me, in Germany, no workarounds worked properly, so I bought a small mobile LTE router and got a second SIM, with both data and voice now going through that. The phone SIM's provider needs to offer voice over wifi aka wifi calling, though, for voice to work...)
I did have issues with data and voice with LTE band as well but with the current settings I chose, it works flawless for both data and voice but I am limited to data speed H+. WiFi has never been an issue for me. It could vary maybe on each phone, maybe they are all built slightly differently and of course carriers use different bands.
Edited by mangled
Over in fxtec pro1x discord forum, a post-er says a beta tester just uploaded results that might entail a software workaround for these hardware difficulties. Best to remain skeptical, but I do want to see where this goes.
  • Thanks 3
On 8/31/2023 at 1:32 PM, mangled said:
Try changing the preferred network type under SIMs settings. I found that the default one often resulted in disconnections. For me tdcdma/wcdma worked good for network stability.
It seems to be better as you explained
