kirkhurbing 0 Posted October 14, 2024 Share Posted October 14, 2024 So I received my phone not too long ago and I had to install lineage OS 21 to fix the keyboard problem AZERTY phones have (as documented by @zegoo here : https://community.fxtec.com/topic/4113-problem-shift-key-with-android-azerty/?do=findComment&comment=69357), and when I put my sim card in (bouygues telecom) everything works fine EXCEPT mobile data. I can make calls, I've checked the APN and everything is fine, I just can't use mobile data. Anybody have an idea of things that I could check ? Quote Link to post Share on other sites
zegoo 13 Posted October 18, 2024 Share Posted October 18, 2024 Hi @kirkhurbing , maybe a missing modem file issue ... You could try the apk PIXEL IMS to get the Bouygues modem file or trying to set up your apn by yourself. Quote Link to post Share on other sites
kirkhurbing 0 Posted October 26, 2024 Author Share Posted October 26, 2024 (edited) On 10/18/2024 at 2:27 AM, zegoo said: Hi @kirkhurbing , maybe a missing modem file issue ... You could try the apk PIXEL IMS to get the Bouygues modem file or trying to set up your apn by yourself. I've already tried setting up the APN with what Bouygues recommends but it didn't work. I just tried downloading pixel IMS but just tells me that nothing is working and I can't do anything about it. Here's a screen As you can see it says no SIM detected but I can call and receive calls without any problems Edited October 26, 2024 by kirkhurbing Quote Link to post Share on other sites
zegoo 13 Posted October 27, 2024 Share Posted October 27, 2024 @kirkhurbingI can't see your screenshot... So, regarding Pixel IMS, i don't understand why it says no SIM detected. Weird if a sim is sloted in. Quote Link to post Share on other sites
kirkhurbing 0 Posted October 28, 2024 Author Share Posted October 28, 2024 maybe this works better if I upload it directly. In case it doesn't work again it says no sim detected, no shizuku service/permission and volte not supported by device Quote Link to post Share on other sites
zegoo 13 Posted October 28, 2024 Share Posted October 28, 2024 Hi @kirkhurbingYour device has to be rooted for shizuku application working fine. Is your phone rooted ? Quote Link to post Share on other sites
kirkhurbing 0 Posted October 28, 2024 Author Share Posted October 28, 2024 I followed the guides on this forum And followed the lineage os tutorial here : https://wiki.lineageos.org/devices/pro1x/install/#enabling-offmode-charging I encountered no problem except I had to install the android drivers in order to fully root the phone Quote Link to post Share on other sites
