[SOLVED] Stuck if Fastboot - Flashing Unlock is not Allowed
SOLVED
I used the factory restore tool. It worked. Note that you must reboot after installing the winusb driver if using windows.
=====ORIGINAL POST======
I received my Pro1 in January and in April, I pulled out my phone and found it was in fastboot. Stuck in fastboot and Start would not start the device.
I tried to follow the instructions to restore stock firmware but I've encounter the error "Flashing Unlock is not Allowed".
Is there anyway to force the unlock or flash the device any other way?
Flash instructions followed:
My bricked phone:
wGun7lg_LVcjdDQwhW0x_hhbfepeJpnqVVWyu05c
Edited by windraver
