Giordyman 0 Posted September 12, 2020 Share Posted September 12, 2020 Hello, guys. Recently, I've tried to root a Cubot Power 4G following a guide I found online. I probably should have been more catious about it, cause now the phone is stuck on a bootloop. I tried to install a custom recovery to try and fix this, but as there was no official twrp for Cubot, I once again downloaded something that was probably shady. Thus, now the phone is stuck on bootloop, won't access recovery mode, is now turned off because battery gave out, but if I try to connect it to the pc, it will start to bootloop again. I cannot access adb, or at the least I don't know a way to, since it keeps bootlooping and I have no way to access a recovery mode(since there's no one, or at the least, if there is, it's faulty). What can I do here? Quote Link to post Share on other sites
EskeRahn 5,596 Posted September 12, 2020 Share Posted September 12, 2020 I will suggest to try XDA or the forum for that device/brand. This is the user forum for the F(x)tec Pro1 1 2 Quote Link to post Share on other sites
