Slion 1,201 Posted August 30, 2021 Share Posted August 30, 2021 (edited) Just wanted to provide links to source files that makes our Pro¹ keyboard. That can be used as reference for anyone wanting to understand and customise Pro¹ keyboard experience by building Lineage OS. From low to high level files we have identified the followings key components: Device Tree Structure Include, contains GPIO pin mapping to scan codes:https://github.com/LineageOS/android_kernel_fxtec_msm8998/blob/lineage-18.1/arch/arm/boot/dts/qcom/msm8998-qrd-skuk-t5.dtsiPermalink Driver, brings together GPIO and aw9523b controller input to define the scan codes sent to user space:https://github.com/LineageOS/android_kernel_fxtec_msm8998/blob/lineage-18.1/drivers/input/keyboard/qx1000.c Key Layout, maps scan codes to Android Key Codes, you have both the generic Android key layout which should not be modified and our device specific layout which you can customize:https://android.googlesource.com/device/google/atv/+/master/Generic.klhttps://github.com/LineageOS/android_device_fxtec_pro1/blob/lineage-18.1/keylayout/gpio-keys.klhttps://github.com/LineageOS/android_device_fxtec_pro1/blob/lineage-18.1/keylayout/Builtin_Keyboard.kl Key Character Map, maps possibly modified key codes to final key codes:https://github.com/LineageOS/android_device_fxtec_pro1/blob/lineage-18.1/keychars/Builtin_Keyboard.kcm From our device makefile you should be able to work out what is actually used during our build process:https://github.com/LineageOS/android_device_fxtec_pro1/blob/lineage-18.1/device.mk Pro1 specific driver keymap indices:http://www.keyboard-layout-editor.com/#/gists/086488022ce3789b560dcd682c89b0da Meta Search key system shortcut handler:https://android.googlesource.com/platform/frameworks/base/+/master/services/core/java/com/android/server/policy/PhoneWindowManager.java#2890 Meta Search key system shortcut definitions:https://android.googlesource.com/platform/frameworks/base/+/master/core/res/res/xml/bookmarks.xml Those are loaded from: https://android.googlesource.com/platform/frameworks/base/+/master/services/core/java/com/android/server/policy/ShortcutManager.java#104 Not sure why Meta+A does not launch the Calculator though. Display system keyboard shortcuts dialog:https://android.googlesource.com/platform/frameworks/base/+/android-7.0.0_r1/packages/SystemUI/src/com/android/systemui/statusbar/KeyboardShortcuts.java For your application to register shortcuts see how it is done in Lineage Trebuchet launcher:https://github.com/LineageOS/android_packages_apps_Trebuchet/blob/c8d5010b1071873957ff9f4b56ed5de1ca9471b4/src/com/android/launcher3/Launcher.java#L2621 To handle them:https://github.com/LineageOS/android_packages_apps_Trebuchet/blob/c8d5010b1071873957ff9f4b56ed5de1ca9471b4/src/com/android/launcher3/Launcher.java#L2652 Meta shortcuts are defined there it seems: https://android.googlesource.com/platform/frameworks/base/+/master/core/res/res/xml/bookmarks.xml Omissions Those are apparently not used for Pro¹:https://github.com/LineageOS/android_kernel_fxtec_msm8998/blob/lineage-18.1/arch/arm/boot/dts/qcom/msm8998-qrd-skuk-QX1000.dtsi Edited September 18, 2021 by Slion 1 9 Quote Link to post Share on other sites
