Jfrelish 13 Posted January 1, 2022 Share Posted January 1, 2022 Hello all, I finally got my broken fxtec Pro 1 screen replaced and noticed that I am missing my sd card tray, which phone has a compatible sd card tray? 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted January 1, 2022 Share Posted January 1, 2022 I think it will be pure luck if you find one that matches completely. The one that I got on my pre-production unit is quite different from the one on the retail unit. The inner 'frame' that hold the cards might be a standard item, but the curved outer part hardly is. (the left one is retail) So try contacting support to get a spare part. Quote Link to post Share on other sites
Jfrelish 13 Posted January 1, 2022 Author Share Posted January 1, 2022 Thank you! 1 Quote Link to post Share on other sites
