64_Tesseract 0 Posted March 4, 2022 Share Posted March 4, 2022 I'm looking to buy one of these phones but I'm not sure if I'll be able to install LineageOS on the Pro1X. The fxtec website lists it as an OS, but the Lineage website only has the Pro1, and not the Pro1X. Is there too much of a difference between processors, or will it work for both models? Is it even possible to buy the Pro1 from here? The buy button for it just links to the Pro1X... Quote Link to post Share on other sites
VaZso 1,999 Posted March 4, 2022 Share Posted March 4, 2022 @64_Tesseract Pro1 and Pro1-X are not compatible, LineageOS should has a separate branch for these phones. However, official support should arrive also for Pro1-X after it becomes available, it is a work in progress as far as I know. Also, Pro1 can not be bought anymore because its heart (the SoC) became unavailable for F(x)tec. 2 Quote Link to post Share on other sites
