Liza 3 Posted February 8, 2023 Share Posted February 8, 2023 New screen (glass + digitiser) to replace broken pro1 screen arrived at 11 ish this morning and was fitted and phone nicely working 1/2 hour later. Support sent a link to the How to video and that was helpful. Nice and simple fix, although obvs the more expensive route. 1 Quote Link to post Share on other sites
Hook 3,366 Posted February 8, 2023 Share Posted February 8, 2023 Just to clarify, I am assuming (because you said expensive) you are referring to getting the complete setup from FxTec that includes the frame. Nice! I will always go that route if I need a replacement as long as they are available. 1 Quote Link to post Share on other sites
Liza 3 Posted February 8, 2023 Author Share Posted February 8, 2023 Yes, complete unit - £149 + £20 FedEx next day. So now I assume I've got a spare digitizer under that broken glass?? Pity I'll have to disassemble the whole unit again to test it 😅 23 minutes ago, Hook said: Just to clarify, I am assuming (because you said expensive) you are referring to getting the complete setup from FxTec that includes the frame. Nice! I will always go that route if I need a replacement as long as they are available. 1 Quote Link to post Share on other sites
