Andre 0 Posted November 9, 2023 Share Posted November 9, 2023 Hello, i have installed Lineage 20 on my Pro1 today. Before i used the Stock OS. I know the Hall Sensor who detects if the Pro1 is opened or closed is broken on my Phone. That was no Problem on the Stock OS. I deactivated in the Slider Option Landscape when opened and everything worked fine. Now the Pro1 stucks in Landscape and there is no Slider Option on Lineage. Is there a other way to deactivate Landscape when opened? Greetings Andre Quote Link to post Share on other sites
Rob. S. 1,667 Posted November 9, 2023 Share Posted November 9, 2023 The one workaround I've found for my old Pro1 with LineageOS which has the same problem is to use the 'Rotation Control Pro' app which I already had installed anyway. I disabled 'per app settings' and now I manually switch between portrait and landscape with the app's controls. 1 2 Quote Link to post Share on other sites
