Aeong 4 Posted August 25, 2024 Share Posted August 25, 2024 (edited) When I select Miracast Display from the 'Transfer' menu, it says 'WFD Service has stopped.' and nothing happens. This does not happen on all devices, and it worked normally when connected to an Android Smart TV. The display that is causing this error is an old mini beam projector with Android 5.1. It worked fine when I connected to this projector with a BlackBerry Keytwo. I am using LineageOS 21. Is there a solution for this? Edited August 25, 2024 by Aeong Quote Link to post Share on other sites
