cash 18 Posted January 20, 2025 Share Posted January 20, 2025 Hello, I finally received my phone (albiet with a dead battery that required dissasembly), but I guess it is used, as Android has a PIN. I have tried all of the common PINs and no luck. I have tried to boot into bootloader using power + vol down. I however get a broken robot icon with the text "No command" I have tried recover mode using power + vol up, but this just boots into Android. If I connect to my PC and use the command "adb devices" I get this response: List of devices attached 778c00e6 unauthorized The bootloader also seems to be locked, so I'm not sure what else to do. Thanks Quote Link to post Share on other sites
