cz800cr 2 Posted February 28, 2019 Share Posted February 28, 2019 I want to use this phone in Japan. Please support Japan band (LTE and WCDMA B19). Moto Z2 force edition (for UK XT1789-06) is support this band. https://www.motorola.co.uk/products/moto-z-force-edition-gen-2 Quote Link to post Share on other sites
B.X 19 Posted February 28, 2019 Share Posted February 28, 2019 Will the Pro1 have support for VoLTE (Voice over LTE) support? Can anyone translate the supported radio bands into US carriers? Quote Link to post Share on other sites
shabbypenguin 0 Posted February 28, 2019 Share Posted February 28, 2019 GSM: 2, 3, 5, 8 WCDMA: 1, 2, 4, 5, 8 CDMA/EVDO: BC0, BC1 TD-SCDMA: 34/39 TDD-LTE: 38/39/40/41(100mhz) FDD-LTE: 1, 2/25, 3, 4, 5/26, 7, 8, 12/17, 13, 20, 28, 66 Tmobile uses bands 2, 4, 5, 12, 66 for LTE. the only bands its missing for full and complete support there is 17 and 71. 2g and 3g should work as well for tmo. Quote Link to post Share on other sites
bob3k 0 Posted February 28, 2019 Share Posted February 28, 2019 Will it work on Verizon? Quote Link to post Share on other sites
shabbypenguin 0 Posted February 28, 2019 Share Posted February 28, 2019 verizon appears to use band 2, 4 and 13 for LTE all of which are supported, as is the cdma aspect. so if you can convince verizon to activate the device you should have entirely full support. without the cdma aspect, youll have just LTE/volte support. AT&T uses 2, 4, 5, 12, 17 for LTE and as such should be fully supported. Sprint uses 25, 26, 41. im not sure how that will work for sprint customers due to cdma locks and they arent required to allow LTE free run like VZW does. so overall probably least likely to get any kind of support on sprint, similarly us cellular as well. Quote Link to post Share on other sites
Lunasaur 1 Posted March 3, 2019 Share Posted March 3, 2019 Google Fi? 1 Quote Link to post Share on other sites
Josh.mck 0 Posted March 4, 2019 Share Posted March 4, 2019 I was just wondering if the phone will work on all the Australian phone networks? Quote Link to post Share on other sites
lameboyadvance 98 Posted March 4, 2019 Share Posted March 4, 2019 According to the Fxtec website Pro1 network support is as following: Global LTE (FDD+TDD), WCDMA/UMTS, CDMA/EVDO, GSM/EDGE Cellular Bands; GSM: 2, 3, 5, 8 WCDMA: 1, 2, 4, 5, 8 CDMA/EVDO: BC0, BC1 TD-SCDMA: 34/39 TDD-LTE: 38/39/40/41(100mhz) FDD-LTE: 1, 2/25, 3, 4, 5/26, 7, 8, 12/17, 13, 20, 28, 66 Since our frequencies are 3G bands 1, 5, 8 and 4G bands 1, 3, 5, 7, 8, 28 & 40, yes it does work here, as well as in a lot of other countries. Quote Link to post Share on other sites
RaceQ 0 Posted March 6, 2019 Share Posted March 6, 2019 @Josh.mck The link mentioned by @lameboyadvance - Aus Mobile Network Frequencies under heading "Importing Phones from Overseas" For full compatibility in Australia with all carriers, it is recommended that you use a phone with the following bands: 3G: 850 / 900 / 2100 [also referred to as 5 / 8 / 1 respectively] 4G: Bands 1, 3, 5, 7, 8, 28, 40. For 4G, Band 3 and 28 are the most commonly used. If a phone has band 28 available, it is likely to have all the bands you need. the other sections are complex to understand. Just clarifying because 1 / 5 / 8 numbers initially puzzled me :-) Quote Link to post Share on other sites
elitistpandaz 0 Posted March 9, 2019 Share Posted March 9, 2019 Also wondering if it will work with Google Fi/US Cellular Quote Link to post Share on other sites
nbtodd 0 Posted March 13, 2019 Share Posted March 13, 2019 Also wondering if it will work with Google Fi/US Cellular US Cellular compatible. Quote Link to post Share on other sites
