Retlaw 0 Posted April 2, 2019 Share Posted April 2, 2019 Buenos dias.- Estoy interesado en comprar 2 unidades del modelo PRO 1, pero deseo saber: 1) ¿Exportarán a Sudamerica? 2) ¿El modelo PRO 1 puede funcionar en Sudamerica? Gracias por los comentarios. Saludos desde Callao Peru. Quote Link to post Share on other sites
EskeRahn 5,596 Posted April 2, 2019 Share Posted April 2, 2019 2) Du kan se hvilke bånd der understøttes under specs "Network" nederst her Oh, you see it might not be that practical if we all write in our native tongue. Please write your post in English. ;) and on 1) I do not see why it should not be possible to send it to e.g. Peru. Quote Link to post Share on other sites
netman 1,424 Posted April 2, 2019 Share Posted April 2, 2019 Puedes usar Google Translate para entender y ayudar a escribir en inglés. I believe when the phone actually ships the shipping cost for your location will be calculated and told. If I understand it the phone should work just fine in South America. Quote Link to post Share on other sites
