foxfreejack 60 Posted February 6, 2020 Share Posted February 6, 2020 Currently there does not seem to have an option to not show the onscreen circle popup when entering pin on pre-boot and once booted up. Being security conscious, I always disable this to make it less obvious to someone else looking at the device. On pre-boot pin entry, the circle is more subtle, but while device is booted, this popup circle is far less subtle. Thank you in advance. Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 6, 2020 Share Posted February 6, 2020 What do you mean by "onscreen circle" Is this a PIN only? I use Password, and get a line and a keyboard under the digital clock Quote Link to post Share on other sites
foxfreejack 60 Posted February 7, 2020 Author Share Posted February 7, 2020 (edited) Hi, I meant the overlay that surrounds the touched surface. See image... Edited February 7, 2020 by foxfreejack Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 7, 2020 Share Posted February 7, 2020 5 hours ago, foxfreejack said: Hi, I meant the overlay that surrounds the touched surface. See image... Ah I see. You can use numbers as a password. When entering a password, the dialogue is a lot less visible Quote Link to post Share on other sites
