Toby Lerone 17 Posted June 18, 2020 Share Posted June 18, 2020 I have a really, really frustrating issue that I've just managed to pin down. When I reboot the phone, it loses some defaults and some app settings, but some are OK. The two main ones that really p*** me off - because I use them literally all of the time are the double press for camera app choice is reset (even if you click always - I use opencamera because snapdragon camera isn't stable) along with other file dialog app choices where you have selected 'always' for the app to open, and on every reboot you have tell onedrive to restart camera photo syncing. Anyone else have this issue? I've tried to google it, and can't find any recent-ish information, or many relevant results at all! My google-fu is letting me down... Thank goodness since changing from 2.4GHz to 5GHz my phone no longer randomly reboots, but having to remember to go and setup app choices again after you manually reboot is getting to me. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted June 19, 2020 Share Posted June 19, 2020 That one is new to me 😥 What are the other defaults you need to reset? Quote Link to post Share on other sites
Toby Lerone 17 Posted June 19, 2020 Author Share Posted June 19, 2020 I don't know if I'm honest - there are things which I swear I've changed and then have reverted without me noticing, but I can't think of any. I assumed it was always me being an idiot, but I'm not sure it is 😕 When I get a chance I'll do a factory reset and see if that fixes anything. Quote Link to post Share on other sites
