CornholioGSM 369 Posted August 9, 2020 Share Posted August 9, 2020 (edited) Hello, i have little problem. On my brand new two days unpacked fx i have some dead pixels on bottom left edge. My problem is when i spot it first time then i will problem with it always 😞 ...it is like on old trinitron crt monitor...when you see two horizontal lines 🙂 I mean that fx wont post me new display...or maybe can post it? It is approx 6-8 pixels on round edge. My question is...will be possible to tell to LOS to cut some of bottom of display? I mean approx made more rounded bottom edges?  Edited August 9, 2020 by CornholioGSM 2 Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 10, 2020 Share Posted August 10, 2020 There are tools out there that can make black borders of the size you wish. If I recall right, one is called "Edge Null". They do require a rather high level of privileges though. Quote Link to post Share on other sites
CornholioGSM 369 Posted August 10, 2020 Author Share Posted August 10, 2020 i mean that that can be something edited inside los (with full root via notepad) Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 10, 2020 Share Posted August 10, 2020 6 minutes ago, CornholioGSM said: i mean that that can be something edited inside los (with full root via notepad) It comes with a touch-margin feature build in, but that wont help you here. 1 Quote Link to post Share on other sites
Featured Comment CornholioGSM 369 Posted August 10, 2020 Author Featured Comment Share Posted August 10, 2020 ...round corners apk from xda labs works fine 🙂 3 Quote Link to post Share on other sites
Posted by CornholioGSM,
3 reactions
Go to this post
