lawliett 77 Posted February 6, 2021 Share Posted February 6, 2021 (edited) Is there a way to allow unlimited fingerprint sensor attempts with los17? Sometimes my fingerprint sensor works and other times it doesn't. I think it might be this issue: https://community.fxtec.com/topic/2509-lineageos-current-status-160-test-builds/?do=findComment&comment=45796 I'm not sure if it was ever fixed: https://github.com/tdm/android_device_fxtec_pro1/issues/31 Apparently, if the phone is squeezed with keyboard closed, it registers a keypress, which wakes up screen and this interferes with fingerprint unlock. Is there any fix for this? Edited February 6, 2021 by lawliett Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 6, 2021 Share Posted February 6, 2021 The limit has a time-out, and if I remember right there has already been added a fix so that multiple attempts in very short succession does not count, that is basically what would would happen if you held the device on/close to the sensor. 1 Quote Link to post Share on other sites
lawliett 77 Posted February 7, 2021 Author Share Posted February 7, 2021 Yes, I think it's a different issue since it's working normally now. Although I notice I have to squeeze somewhat hard on the reader for it to pick up my print properly. Is that normal? I only ask because on my samsung phone the lightest touch seemed to register with the reader very quickly. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 7, 2021 Share Posted February 7, 2021 13 hours ago, lawliett said: Yes, I think it's a different issue since it's working normally now. Although I notice I have to squeeze somewhat hard on the reader for it to pick up my print properly. Is that normal? I only ask because on my samsung phone the lightest touch seemed to register with the reader very quickly. Normally only a light touch is needed on the Pro1 too, so you could have a hardware issue... Quote Link to post Share on other sites
lawliett 77 Posted February 7, 2021 Author Share Posted February 7, 2021 (edited) Actually, light touches work, too. What's happening is that sometimes the reader doesn't register my fingerprint, so I instinctively feel I need to squeeze down harder on the reader to firmly press my fingerprint against it. If I lightly tap it, sometimes the fingerprint is read, sometimes it isn't. I think the issue is the placement of my finger, or maybe the reader is just a bit slower to unlock compared to the samsung phone, so I'm not used to it. Sometimes there's a slight delay between reading the print and hearing the sound of the phone unlocking. Edited February 7, 2021 by lawliett Quote Link to post Share on other sites
EskeRahn 5,596 Posted February 7, 2021 Share Posted February 7, 2021 I think what you experiencing is the deliberately added delay to reduce the dreaded "Too many retries" that is quite common on stock. The delay after an error, reduce the risk of the (from a human perspective) 'same' press of an accidental touch, to be registered as a series of failed retries. Note that a case or shell practically eliminates accidental triggering the fingerprint reader. Quote Link to post Share on other sites
