kashif 350 Posted April 23, 2021 Share Posted April 23, 2021 Hi Guys I just bought a Pro1 and all seems to be fine except the keyboard. The top number key is fine but all the rows below are incorrect. so it seems like when i press a key its always the one below. for example if i press g it will type h, and if i type f it will type g. i am wondering is it a setting issue? can someone help me please to resolve this issue Many Thanks Quote Link to post Share on other sites
kashif 350 Posted April 23, 2021 Author Share Posted April 23, 2021 I have sorted it out. its qwertz so i had to select german instead of english. that makes kb works correctly 2 Quote Link to post Share on other sites
VaZso 1,999 Posted April 23, 2021 Share Posted April 23, 2021 17 minutes ago, kashif said: I have sorted it out. its qwertz so i had to select german instead of english. that makes kb works correctly Exactly. You may also try Finqwerty if you would like to use other layouts fit for QWERTZ keyboard. 1 1 Quote Link to post Share on other sites
