TechLvr 4 Posted November 23, 2022 Share Posted November 23, 2022 I'm having another keyboard issue which I also found mentioned here: Specifically the part which states "...sometimes it produces some random characters inside a word. Sometimes the cursor jumps randomly somewhere. Sometimes it switches Caps lock on when I don't press any button even near to caps. And yes, sometimes I got the pop up caused by long press, which I obviously didn't press." All of these things happen to me when typing very fast on the physical keyboard." Odd enough, after installing Swiftkey, the frequency of random characters dropped down considerably. However, activating the Caps Lock by itself increased substantially. Worse is when it automatically generates some special key press(es) because that really fouls up the typing by moving the cursor, or worse, by sending the text message I'm in the middle of writing, or editing. I can't even find a physical key to send the message on the keyboard. I only know of the button (so to speak) on the touch screen to send it! However, clearly, there some corresponding key code that will send the message (does anyone happen to know what it is?) and the random character generation triggers it sometimes. As I become more and more acclimated to the keyboard, I'm typing faster and faster. This is becoming a real problem because the frequency at which it occurs is directly proportional to typing speed. For instance, when hunting and pecking at a slow speed, it never happens. Has anyone else experienced this? Is it a known issue (I only found the one link above mentioning it)? Is it something specific to Lineage? 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 23, 2022 Share Posted November 23, 2022 (Depending of program combos like Shift+Enter or Ctrl+Enter might send) Quote Link to post Share on other sites
TechLvr 4 Posted November 28, 2022 Author Share Posted November 28, 2022 On 11/23/2022 at 1:27 PM, EskeRahn said: (Depending of program combos like Shift+Enter or Ctrl+Enter might send) No luck with either. I would like to find the key combo so I can try to remap it. Any other guesses?? Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 29, 2022 Share Posted November 29, 2022 49 minutes ago, TechLvr said: No luck with either. I would like to find the key combo so I can try to remap it. Any other guesses?? Not any obvious guesses no. Quote Link to post Share on other sites
TechLvr 4 Posted November 29, 2022 Author Share Posted November 29, 2022 Bummer. I'll see about contacting the app folks to see if they have any input. Thanks for the input! Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 29, 2022 Share Posted November 29, 2022 Just one guess: Does Tab (or Shift+Tab) inside the app switch field/control? If so, it MIGHT jump to the send-button, so some following space or enter would do the actual send. It is not uncommon for apps to do this, e.g. Textra. Quote Link to post Share on other sites
