tomb 6 Posted August 17, 2023 Share Posted August 17, 2023 My screen broke. Before I got the new screen I logged in by connecting it to computer, swiping up and entering password on the keyboard. Since then I configured USB to always set to file&share and it no longer works with a screen, and also no longer worked with computer, which is what I was trying to do. Anyway, I replaced the screen, but am having issues connecting the dual headed connector inside, so only once stuff appeared on the new screen flickering, I have tried reconnecting all the connectors for hours, and mostly get a flickering power light as the connectors dont seem to connect right, even though they look connected. So I tried to connect to an external TV again using USB-C to HDMI. When I press the power buttno, the TV shows the "time and phone is locked (padlock) screen", normally I would swipe up and enter my password, but as the new screen is not connected properly I assume I can't use it, so I am trying to find the right keyboard combination to tell the phone I want to enter my password. I am running Lineage 18.1. So far I press the power button, this causes the TV to detect a signal showing a padlock. I enter my password and press enter or any other non password and press enter, but the TV goes back to blank once enter is pressed no matter what was entered. I am wondering what key I need to press that emulates swiping up on the phone to tell it you want to enter your password. I tried enter, tab and escape, and cursor up, I cant be sure they do or don't work as nothing appears on the phone screen as I can't get it connected right. thanks. 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted August 18, 2023 Share Posted August 18, 2023 16 hours ago, tomb said: am wondering what key I need to press that emulates swiping up on the phone to tell it you want to enter your password. Space might do the trick, it does on plain android 1 1 Quote Link to post Share on other sites
