daxxy 2 Posted April 14, 2019 Share Posted April 14, 2019 Hey, so I just tried to reply to this topic: https://www.fxtec.com/forums/topic/design-the-qwertz-layout/page/8/#post-12822 Given the subject, I had to use literal backticks in my post, and the forum software interpreted those as code tags. Tried to fix it by editing the post to use triple-backticks (some markdown parsers let you escape backticks this way), didn't help. Edited the post again, this time using HTML entities (try to edit a post containing less-than or greater-than characters and that's how they show up in the editor) - now the post disappeared... Quote Link to post Share on other sites
EskeRahn 5,596 Posted April 14, 2019 Share Posted April 14, 2019 The forum software has a (known) bug that editing a comment multiple times incorrectly triggers the spam-system, as if (almost) the same was posted multiple times. I have 'unspammed' it. Unfortunately I do not know a consistent way of escaping special chars, except writing them as url encode. That is an ampersand # the decimal number and a semicolon. e.g. [ for [ (I tried to fix the comment with ` - hope this was what you intended) Quote Link to post Share on other sites
daxxy 2 Posted April 15, 2019 Author Share Posted April 15, 2019 Yeah, in fact, that's exactly what I was trying to do with my last edit (well, I only changed one instance in that, to check if it works). Thanks! Quote Link to post Share on other sites
Waxberry 638 Posted April 15, 2019 Share Posted April 15, 2019 Thanks Eske for the unspamming. There is indeed a known bug of system automatically mark a normal post as spam. Our Dev is doing best to fix it. Sorry for any inconvenience and thanks again for understanding and Eske's prompt help. :) Quote Link to post Share on other sites
