Jacob_S 128 Posted May 19, 2019 Share Posted May 19, 2019 Is it possible to disable autocorrect? On the Motorola Milestone (2) it was possible to have the suggestions displayed but not have them inserted automatically. That is something I would consider important for a keyboard phone. On the BlackBerry PRIV you can't turn autocorrect off and it happens to me a lot that I have to rewrite words that were correct but the software didn't know. Quote Link to post Share on other sites
_DW_ 628 Posted May 21, 2019 Share Posted May 21, 2019 Add them to you dictionary, but I agree! I do not want auto correct full stop when using the keyboard I will fix it myself automatically and if using a terminal or something your going to be typing a lot of things that are not in a dictionary. Quote Link to post Share on other sites
EskeRahn 5,593 Posted May 21, 2019 Share Posted May 21, 2019 Add them to you dictionary, but I agree! I do not want auto correct full stop when using the keyboard I will fix it myself automatically and if using a terminal or something your going to be typing a lot of things that are not in a dictionary. As with so many things, OPTIONS is the answer. I do not see why one user group should be forced to use the setting the other group prefers. So I certainly hope they will have a switch for it, so both can have what they prefer. And some (like me) can turn it off/on depending on what we are currently entering... (With the pro-production unit I tested, it is off, when not displaying a virtual keyboard. But the keyboard software part is clearly not finished) Quote Link to post Share on other sites
