Craig 1,435 Posted November 9, 2019 Share Posted November 9, 2019 (edited) 6 hours ago, david said: I still use Cyanogenmod, and it didn't remove any google pieces. Is this something they started with the first LineageOS versions or something more recent? And do they provide options for keeping the Google pieces? Which pieces are removed, by the way? Not having the Play Store would be a bit inconvenient, if someone did want it. CM11 (Kitkat) defiantly didn't include gapps which is when I started using it.... what version are you using that included gapps? Must be old version. I think way way way back they included gapps but at some point google said no, so they removed em. opengapps.org shows the various options for installing gapps, there are minimal versions with just enough for play store, if that's what you want. Edited November 9, 2019 by Craig 2 Quote Link to post Share on other sites
david 929 Posted November 9, 2019 Share Posted November 9, 2019 39 minutes ago, Craig said: CM11 (Kitkat) defiantly didn't include gapps which is when I started using it.... what version are you using that included gapps? Must be old version. I think way way way back they included gapps but at some point google said no, so they removed em. opengapps.org shows the various options for installing gapps, there are minimal versions with just enough for play store, if that's what you want. When I saw "gapps", I remembered that was a separate install. I completely forgot about that. I haven't had to install it for years. I just used nandroid to move everything from one phone to another. I'm on CM11 too. That was the last one made for the Relay 4G. Quote Link to post Share on other sites
