EvilDragon 164 Posted December 22, 2019 Share Posted December 22, 2019 I've created a small tutorial that might help you to get around some quirks you might have with your F(x) Tec Pro1. Let me know what you think about it and if you have further suggestions which I can add to it :) It's available both in German and English and you can find it here: https://www.dragonbox.de/index.php?fc=module&module=ybc_blog&controller=blog&id_post=9 2 11 Quote Link to post Share on other sites
divstar 164 Posted December 22, 2019 Share Posted December 22, 2019 Thank you! Now that's awesome support. Didn't decide to root my pro1, but TBH I am not happy with the built-in launcher as it annoys me when I pull from bottom, because it shows the recent apps. I have to pull again to actually open the apps view. So I think I will give Total Launcher a try. Quote Link to post Share on other sites
adidas88 29 Posted December 22, 2019 Share Posted December 22, 2019 thank you very very much... the hint to shut down the edges was just needed. Quote Link to post Share on other sites
Hook 3,316 Posted December 22, 2019 Share Posted December 22, 2019 1 hour ago, divstar said: Thank you! Now that's awesome support. Didn't decide to root my pro1, but TBH I am not happy with the built-in launcher as it annoys me when I pull from bottom, because it shows the recent apps. I have to pull again to actually open the apps view. So I think I will give Total Launcher a try. That isn't the launcher. That's Pie. You can change it back to the old style in Settings->System->Gestures turn off swipe up on home. 1 4 Quote Link to post Share on other sites
divstar 164 Posted December 22, 2019 Share Posted December 22, 2019 29 minutes ago, Hook said: That isn't the launcher. That's Pie. You can change it back to the old style in Settings->System->Gestures turn off swipe up on home. Wow, thank you very much! 1 Quote Link to post Share on other sites
EvilDragon 164 Posted December 23, 2019 Author Share Posted December 23, 2019 2 hours ago, adidas88 said: thank you very very much... the hint to shut down the edges was just needed. Yeah, that was driving me crazy myself - so I had to look for a solution 😄 Quote Link to post Share on other sites
