puppymang 13 Posted January 28, 2020 Share Posted January 28, 2020 (edited) brand new pro1 it just arrived today. i turned it on and when i got home i put in my verizon sim after skipping the initial setup. went through the advanced menu to toggle votle and data/calling works fine but wifi will not connect. if i add my home network it just says saved and never attempts to connect. i downloaded all the latest updates for the stock device and nothing. any ideas? edit: it looks like it works under 2.4ghz but not 5ghz. i was under the impression this device supports both? Edited January 28, 2020 by puppymang Quote Link to post Share on other sites
EskeRahn 5,598 Posted January 28, 2020 Share Posted January 28, 2020 It works fine on mine, have you tried another router? Would be interesting to know if it a matter of your unit not able to do 5GHz WiFi at all, or the Pro1 in general has a protocol issue with a specific router type/brand. 1 Quote Link to post Share on other sites
david 929 Posted January 28, 2020 Share Posted January 28, 2020 And if your router has 2 radios for 5GHz, try the other one to see if it makes a difference. They will usually be at different ends of the 5 GHz bands. 1 Quote Link to post Share on other sites
