Slion 1,201 Posted February 9, 2020 Share Posted February 9, 2020 Does anyone know where is the light sensor located on Pro1? Quote Link to post Share on other sites
divstar 164 Posted February 10, 2020 Share Posted February 10, 2020 From what I can tell it's left of the front-camera. You can try a diagnostic app (built-in), described in the following post: This helped me figure out where the sensors were and if they work as expected. Be careful with the settings and do read that specific post in full before doing anything. 1 Quote Link to post Share on other sites
Slion 1,201 Posted February 10, 2020 Author Share Posted February 10, 2020 Thanks for the link. Using that Sensors Test application it looks like our light sensor is just left of the ear piece speaker. 1 Quote Link to post Share on other sites
CornholioGSM 370 Posted February 10, 2020 Share Posted February 10, 2020 you can use camera on another phone for find sensor 🙂 2 1 Quote Link to post Share on other sites
EskeRahn 5,598 Posted February 11, 2020 Share Posted February 11, 2020 It is slightly left of the speaker. Note that it got quite a delay in reacting to changes, but pressing power off and on, triggers a new read. 1 Quote Link to post Share on other sites
