cjacksonz 0 Posted June 10, 2020 Share Posted June 10, 2020 None of the options seem to do anything? They all just take me back to this screen. I'm not exactly phone-savvy, so please be patient. Also, when I try to connect the phone to my PC, the drivers fail to install? Quote Link to post Share on other sites
Digital_Toxin 7 Posted June 11, 2020 Share Posted June 11, 2020 What did you do to end up in this state? Attempt a ROM flash? We need some context to help you out first. 3 1 Quote Link to post Share on other sites
DieBruine 397 Posted June 11, 2020 Share Posted June 11, 2020 Or did you re-lock it again? Quote Link to post Share on other sites
ajstreuk 0 Posted August 31, 2020 Share Posted August 31, 2020 This just happened to me. I didn't do anything with it. I used my phone as I was leaving work and when I got home and pulled it out of my bag, it looked like that. Is there any way to fix this? I am so frustrated and I don't want it to become a brick by using something that won't work. Any suggestions? Quote Link to post Share on other sites
tdm 2,322 Posted August 31, 2020 Share Posted August 31, 2020 9 hours ago, ajstreuk said: This just happened to me. I didn't do anything with it. I used my phone as I was leaving work and when I got home and pulled it out of my bag, it looked like that. Is there any way to fix this? I am so frustrated and I don't want it to become a brick by using something that won't work. Any suggestions? Try the factory flash tool. Make sure to tell it not to flash data, or all your data will be erased. Quote Link to post Share on other sites
divstar 164 Posted September 7, 2020 Share Posted September 7, 2020 So .. I am stuck with the same problem. I have not attempted to even flash the phone at all. I suppose, that the last system update (in contrast to most others it did contain information on what it is going to update) might be the culprit. My screen is nearly the same as the one @cjacksonz has on his picture. No matter what I chose ("Restart bootloader", "Recovery mode", "Power off", "Boot to FFBM", "Boot to QMMI", "Start"), I end up at this very screen cjacksonz showed in the first post. If I detach the USB cord, "Power off" turns off the phone (otherwise it restarts the phone). I have tried fiddling around with Minimal ADB + Fastboot and when doing "fastboot devices", this device is properly seen. "fastboot reboot" restarts the device, but it still restarts into the same screen. I tried Q Flash Tool, but it does not recognize this device as it is in Fastboot Mode. It keeps saying I should connect the device. Does anyone have an idea what to do? Quote Link to post Share on other sites
divstar 164 Posted September 7, 2020 Share Posted September 7, 2020 remoteadmin@...$ sudo fastboot getvar all (bootloader) hw-revision:20001 (bootloader) unlocked:no (bootloader) off-mode-charge:0 (bootloader) charger-screen-enabled:0 (bootloader) battery-soc-ok:yes (bootloader) battery-voltage:3950 (bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) erase-block-size: 0x1000 (bootloader) logical-block-size: 0x1000 (bootloader) variant:MSM UFS (bootloader) partition-type:fsc:raw (bootloader) partition-size:fsc: 0x1000 (bootloader) partition-type:fsg:raw (bootloader) partition-size:fsg: 0x200000 (bootloader) partition-type:modemst2:raw (bootloader) partition-size:modemst2: 0x200000 (bootloader) partition-type:modemst1:raw (bootloader) partition-size:modemst1: 0x200000 (bootloader) partition-type:storsec:raw (bootloader) partition-size:storsec: 0x20000 (bootloader) partition-type:logdump:raw (bootloader) partition-size:logdump: 0x4000000 (bootloader) partition-type:sti:raw (bootloader) partition-size:sti: 0x200000 (bootloader) partition-type:logfs:raw (bootloader) partition-size:logfs: 0x800000 (bootloader) partition-type:toolsfv:raw (bootloader) partition-size:toolsfv: 0x100000 (bootloader) partition-type:limits:raw (bootloader) partition-size:limits: 0x1000 (bootloader) partition-type:splash:raw (bootloader) partition-size:splash: 0x20A4000 (bootloader) partition-type:dpo:raw (bootloader) partition-size:dpo: 0x1000 (bootloader) partition-type:msadp:raw (bootloader) partition-size:msadp: 0x40000 (bootloader) partition-type:apdp:raw (bootloader) partition-size:apdp: 0x40000 (bootloader) partition-type:dip:raw (bootloader) partition-size:dip: 0x100000 (bootloader) partition-type:devinfo:raw (bootloader) partition-size:devinfo: 0x1000 (bootloader) partition-type:sec:raw (bootloader) partition-size:sec: 0x4000 (bootloader) partition-type:vendor_b:raw (bootloader) partition-size:vendor_b: 0x40000000 (bootloader) partition-type:devcfg_b:raw (bootloader) partition-size:devcfg_b: 0x20000 (bootloader) partition-type:cmnlib64_b:raw (bootloader) partition-size:cmnlib64_b: 0x80000 (bootloader) partition-type:cmnlib_b:raw (bootloader) partition-size:cmnlib_b: 0x80000 (bootloader) partition-type:vbmeta_b:raw (bootloader) partition-size:vbmeta_b: 0x10000 (bootloader) partition-type:dtbo_b:raw (bootloader) partition-size:dtbo_b: 0x800000 (bootloader) partition-type:boot_b:raw (bootloader) partition-size:boot_b: 0x4000000 (bootloader) partition-type:keymaster_b:raw (bootloader) partition-size:keymaster_b: 0x80000 (bootloader) partition-type:abl_b:raw (bootloader) partition-size:abl_b: 0x100000 (bootloader) partition-type:dsp_b:raw (bootloader) partition-size:dsp_b: 0x1000000 (bootloader) partition-type:mdtp_b:raw (bootloader) partition-size:mdtp_b: 0x2000000 (bootloader) partition-type:mdtpsecapp_b:raw (bootloader) partition-size:mdtpsecapp_b: 0x400000 (bootloader) partition-type:bluetooth_b:raw (bootloader) partition-size:bluetooth_b: 0x100000 (bootloader) partition-type:modem_b:raw (bootloader) partition-size:modem_b: 0x6E00000 (bootloader) partition-type:pmic_b:raw (bootloader) partition-size:pmic_b: 0x80000 (bootloader) partition-type:hyp_b:raw (bootloader) partition-size:hyp_b: 0x80000 (bootloader) partition-type:tz_b:raw (bootloader) partition-size:tz_b: 0x200000 (bootloader) partition-type:rpm_b:raw (bootloader) partition-size:rpm_b: 0x80000 (bootloader) partition-type:vendor_a:raw (bootloader) partition-size:vendor_a: 0x40000000 (bootloader) partition-type:devcfg_a:raw (bootloader) partition-size:devcfg_a: 0x20000 (bootloader) partition-type:cmnlib64_a:raw (bootloader) partition-size:cmnlib64_a: 0x80000 (bootloader) partition-type:cmnlib_a:raw (bootloader) partition-size:cmnlib_a: 0x80000 (bootloader) partition-type:vbmeta_a:raw (bootloader) partition-size:vbmeta_a: 0x10000 (bootloader) partition-type:dtbo_a:raw (bootloader) partition-size:dtbo_a: 0x800000 (bootloader) partition-type:boot_a:raw (bootloader) partition-size:boot_a: 0x4000000 (bootloader) partition-type:keymaster_a:raw (bootloader) partition-size:keymaster_a: 0x80000 (bootloader) partition-type:abl_a:raw (bootloader) partition-size:abl_a: 0x100000 (bootloader) partition-type:dsp_a:raw (bootloader) partition-size:dsp_a: 0x1000000 (bootloader) partition-type:mdtp_a:raw (bootloader) partition-size:mdtp_a: 0x2000000 (bootloader) partition-type:mdtpsecapp_a:raw (bootloader) partition-size:mdtpsecapp_a: 0x400000 (bootloader) partition-type:bluetooth_a:raw (bootloader) partition-size:bluetooth_a: 0x100000 (bootloader) partition-type:modem_a:raw (bootloader) partition-size:modem_a: 0x6E00000 (bootloader) partition-type:pmic_a:raw (bootloader) partition-size:pmic_a: 0x80000 (bootloader) partition-type:hyp_a:raw (bootloader) partition-size:hyp_a: 0x80000 (bootloader) partition-type:tz_a:raw (bootloader) partition-size:tz_a: 0x200000 (bootloader) partition-type:rpm_a:raw (bootloader) partition-size:rpm_a: 0x80000 (bootloader) partition-type:ddr:raw (bootloader) partition-size:ddr: 0x100000 (bootloader) partition-type:cdt:raw (bootloader) partition-size:cdt: 0x1000 (bootloader) partition-type:xbl_b:raw (bootloader) partition-size:xbl_b: 0x3F5000 (bootloader) partition-type:xbl_a:raw (bootloader) partition-size:xbl_a: 0x3F5000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0x1AE05F3000 (bootloader) partition-type:system_b:ext4 (bootloader) partition-size:system_b: 0xC0000000 (bootloader) partition-type:system_a:ext4 (bootloader) partition-size:system_a: 0xC0000000 (bootloader) partition-type:frp:raw (bootloader) partition-size:frp: 0x80000 (bootloader) partition-type:keystore:raw (bootloader) partition-size:keystore: 0x80000 (bootloader) partition-type:misc:raw (bootloader) partition-size:misc: 0x100000 (bootloader) partition-type:persist:raw (bootloader) partition-size:persist: 0x2000000 (bootloader) partition-type:ssd:raw (bootloader) partition-size:ssd: 0x2000 (bootloader) has-slot:modem:yes (bootloader) has-slot:system:yes (bootloader) current-slot:b (bootloader) has-slot:boot:yes (bootloader) slot-retry-count:b:0 (bootloader) slot-unbootable:b:yes (bootloader) slot-successful:b:no (bootloader) slot-retry-count:a:0 (bootloader) slot-unbootable:a:yes (bootloader) slot-successful:a:no (bootloader) slot-count:2 (bootloader) secure:no (bootloader) serialno:dc4648e9 (bootloader) product:msm8998 (bootloader) max-download-size:536870912 (bootloader) kernel:uefi This is `getvar all` result.. Quote Link to post Share on other sites
EskeRahn 5,598 Posted September 7, 2020 Share Posted September 7, 2020 1 hour ago, divstar said: (bootloader) slot-unbootable:b:yes (bootloader) slot-successful:b:no (bootloader) slot-retry-count:a:0 (bootloader) slot-unbootable:a:yes (bootloader) slot-successful:a:no These certainly explains why it will not boot... But how to get out of this mess is another matter.... If anybody can use it, the similar from mine (on stock) is attached. fastboot getvar all 2>fastboot_getvar_all.txt fastboot_getvar_all.txt Quote Link to post Share on other sites
