mememe 2 Posted July 24, 2020 Share Posted July 24, 2020 My phone only charges for twenty second then it stops this is bad 1 1 Quote Link to post Share on other sites
VaZso 1,999 Posted July 24, 2020 Share Posted July 24, 2020 53 minutes ago, mememe said: My phone only charges for twenty second then it stops this is bad Have you tried another charger and another cable? ...or maybe plugging Type-C connector in the other direction for testing purposes... 3 Quote Link to post Share on other sites
internationaltraitor 84 Posted July 25, 2020 Share Posted July 25, 2020 try different cables, blocks, and plugs, sources like computer or the car. 2 Quote Link to post Share on other sites
mememe 2 Posted July 25, 2020 Author Share Posted July 25, 2020 Only the included charger works, I've tried two other Samsung branded ones, they're the same. So it's not a bad charger, they both work on other phones. why doesn't every usb c charger work with this phone 1 Quote Link to post Share on other sites
FlyingAntero 871 Posted July 25, 2020 Share Posted July 25, 2020 (edited) 27 minutes ago, mememe said: Only the included charger works, I've tried two other Samsung branded ones, they're the same. So it's not a bad charger, they both work on other phones. why doesn't every usb c charger work with this phone Samsung is using its own Fast Charging technology which may not be compatible with Qualcomm Quick Charge 3.0. I can confirm that my Pro1 does not charge with Samsung charger (Fast Charging) but my Xperia XZ1 Compact (QC 3.0) does not charge either. Both work great with QC 3.0 charger and Sony "normal" charger. See more information from here. Quick charging technologys are not compatible very often and even the cable can an issue. Pixel 4 does not charge with Huawei for example. https://www.androidauthority.com/state-of-usb-c-870996/ Edited July 25, 2020 by FlyingAntero 4 Quote Link to post Share on other sites
