haltriumph 3 Posted February 18, 2021 Share Posted February 18, 2021 Hi Everyone: The default notification sound is not working. For example, if I go into settings/sounds/ and try to set the default ringtone, I can hear the options when I click on them. The same is true for default alarm sound. But, when I try to set the default notification sound, I don't hear anything. I also don't hear any sound when a notification comes in. All volumes seem to be up. Any suggestions? Thanks! Quote Link to post Share on other sites
MvBoe 31 Posted February 18, 2021 Share Posted February 18, 2021 It could be that the sound file is defective. Just choose a different tone for the notification. If that works then the problem is probably with the file. Quote Link to post Share on other sites
Hook 3,315 Posted February 18, 2021 Share Posted February 18, 2021 (edited) 17 minutes ago, haltriumph said: Hi Everyone: The default notification sound is not working. For example, if I go into settings/sounds/ and try to set the default ringtone, I can hear the options when I click on them. The same is true for default alarm sound. But, when I try to set the default notification sound, I don't hear anything. I also don't hear any sound when a notification comes in. All volumes seem to be up. Any suggestions? Thanks! Is this with any sound chosen or just the default sound? If all sounds, check volume rocker and also check you didn't accidentally trigger the Do Not Disturb quick tile in the pull down notification shade (I've done that before). Edited February 18, 2021 by Hook 1 Quote Link to post Share on other sites
haltriumph 3 Posted February 18, 2021 Author Share Posted February 18, 2021 This happens no matter what sound I choose. Also, the dnd is not active. Quote Link to post Share on other sites
MvBoe 31 Posted February 18, 2021 Share Posted February 18, 2021 Only to be sure: You tried a Reboot? Quote Link to post Share on other sites
haltriumph 3 Posted February 18, 2021 Author Share Posted February 18, 2021 Reboot worked. I though that I did that, but I guess not. Sometimes I sit and think, but mostly I just sit. Sorry to bother you guys. BTW: I only had my phone for a couple of weeks, but I love it. 1 2 Quote Link to post Share on other sites
