internationaltraitor 84 Posted February 25, 2021 Share Posted February 25, 2021 (edited) for example, if i'm on another rom like lineage, and i would want to install another type of rom like aicp,, only using the sd card, no cables or PC. img and zip files are installed unto the memory card. do i boot into recovery and apply update, or factory reset it first, or ? what would be the steps? main problem is, i can't get the pc to verify fastboot devices... ... and now,, my computer doesn't recognize adb devices,,, let alone fastboot devices.. Edited February 25, 2021 by internationaltraitor Quote Link to post Share on other sites
_DW_ 628 Posted February 25, 2021 Share Posted February 25, 2021 Usually things to try are * Use different ports * Reinstall the ADB driver and ensure its googles (microsoft one doesn't work properly) * Use a different cable (I always use my nintendo switch controller cable) But I guess you probably have done this why asking. TBH I've never tried doing it from SD card so can't advise on that 😞 Quote Link to post Share on other sites
3zet 100 Posted February 25, 2021 Share Posted February 25, 2021 (edited) You can try to download some linux ISO and create live USB, for example Mint one and install missing stuff like adb and fastboot and try there (its possible even on live USB mode so you don't need to install OS on your PC). Edited February 25, 2021 by 3zet mistype 1 Quote Link to post Share on other sites
_DW_ 628 Posted February 25, 2021 Share Posted February 25, 2021 Yeah what 3zet said might be best that way it would be a clean install. I'm trying to remember how I installed the drivers last time but I am pretty sure I just used https://developer.android.com/studio/run/win-usb 1 Quote Link to post Share on other sites
internationaltraitor 84 Posted February 25, 2021 Author Share Posted February 25, 2021 5 hours ago, _DW_ said: Yeah what 3zet said might be best that way it would be a clean install. I'm trying to remember how I installed the drivers last time but I am pretty sure I just used https://developer.android.com/studio/run/win-usb thanks,, that did it for me. it was this google drive that i was missing. i tried the linux one, but it was late and i was waiting for all the downloads and fell asleep. :)) 3 Quote Link to post Share on other sites
_DW_ 628 Posted February 26, 2021 Share Posted February 26, 2021 15 hours ago, internationaltraitor said: thanks,, that did it for me. it was this google drive that i was missing. i tried the linux one, but it was late and i was waiting for all the downloads and fell asleep. :)) Good to hear 🙂 Quote Link to post Share on other sites
