D8s 0 Posted August 10, 2021 Share Posted August 10, 2021 Looking at the new pro1x, and lineage os as a way to get Google out of my life, but I've read about some issues with android carplay needing Google play services. I was hoping to completely get rid of Google, not even have gapps, any thoughts? Quote Link to post Share on other sites
Hook 3,315 Posted August 10, 2021 Share Posted August 10, 2021 If you are talking about Android Auto (maybe it is called Carplay outside the US?), yes, it requires Google Play services. Google maps too. However, music and phone should work fine over BT alone, but you'll need an alternative method of navigation than google maps, like a GPS unit (or in-dash navigation). Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 10, 2021 Share Posted August 10, 2021 Navmii works fine on both stock Android and AICP, so assume it works on Lineage too (The preproduction unit I use for Lineage lacks the GPS antenna) Quote Link to post Share on other sites
CornholioGSM 370 Posted August 16, 2021 Share Posted August 16, 2021 On 8/10/2021 at 10:27 PM, EskeRahn said: .......... (The preproduction unit I use for Lineage lacks the GPS antenna) hmmm....just question... it lacks only antenna it means that prepro have different back cover?....but hw is same? Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 16, 2021 Share Posted August 16, 2021 35 minutes ago, CornholioGSM said: hmmm....just question... it lacks only antenna it means that prepro have different back cover?....but hw is same? AFAIK, it is only minor details that makes it different, like a different keyboard mount (it covers the screws) i'm not sure what else is different. It got no imei, so I can not use it as a phone, so some of the phone antennas might be missing too without me noticing.. Quote Link to post Share on other sites
CornholioGSM 370 Posted August 16, 2021 Share Posted August 16, 2021 13 minutes ago, EskeRahn said: AFAIK, it is only minor details that makes it different, like a different keyboard mount (it covers the screws) i'm not sure what else is different. It got no imei, so I can not use it as a phone, so some of the phone antennas might be missing too without me noticing.. oooh ok...so maybe is missing whole baseband...just like on live demo units 🙂 Quote Link to post Share on other sites
