milp 27 Posted May 3, 2022 Share Posted May 3, 2022 (edited) Hi, i got a drop of water in my usb c port, so now it wont charge anymore. Can someone please tell me 1. Which wireless charger will work with the pro 1? 2. What is the process to replace the USB C port? Which parts do i need to order where? 3. How else could i emergency charge my pro 1? Manually directly at the battery? Any other hacks? Edited May 3, 2022 by milp 1 Quote Link to post Share on other sites
CornholioGSM 366 Posted May 3, 2022 Share Posted May 3, 2022 (edited) Hello, i have writen small tutorial here ....or you can order whole bottom board directly from fxtec...but it will be long waiting for it. Directly charging battery is not good idea...you can littlebit charge it with laboratory power supply , but is needed to watch whole charging process. Fx dont have qi charging. Water inside connector is problem, but it is not whole problem - you must open phone and clean all an resolder all visually coroded parts. Edited May 3, 2022 by CornholioGSM 1 1 Quote Link to post Share on other sites
milp 27 Posted May 3, 2022 Author Share Posted May 3, 2022 I just removed the usb c connector and put some small wires from GND/VBAT to the outside through the USB connector hole. Luckily at work we have all the necessary tools. At some point i guess ill solder a new usb c port. For now i'm absolutely statisfied charging it on my bench PSU. Constant current until 4.2 volts and then constant voltage, right? Again im very happy that this phone is so serviceable. 2 Quote Link to post Share on other sites
pebert 98 Posted June 26, 2022 Share Posted June 26, 2022 guess you already solved it, otherwise use one of these next time https://global.microless.com/product/l-tsa-tp4056-micro-usb-5v-1a-lithium-battery-charging-protection-board-te585-lipo-charger-module-black-blue-bcbg0011/?currency=usd TPA4056 1 Quote Link to post Share on other sites
