sequestris 710 Posted March 4, 2023 Share Posted March 4, 2023 Bluetooth issue I normally encounter when playing music. My phone doesn't disconnect when in the car or using BT earbuds. Signal strength/Connectivity etc I basically work around by doing 1 of 3 things: Using wifi calling when possible Turning off data unless I need to use it Not trying to speak into the handset with my ear and mouth at the same time. (literally caller can not hear me if I do or the call disconnects). I am sure there might be "issues" with my phone that could be troubleshot but it works and I am happy and I don't have to worry about T-Mobile suddenly deciding to cripple my phone. Quote Link to post Share on other sites
Hook 3,318 Posted March 4, 2023 Share Posted March 4, 2023 I believe they have Pro1 parts in London while all the Pro1x IGG stuff comes from Hong Kong. So I think if you set up a battery purchase directly with the London office, you will probably get it. The Pro1 battery is different than the Pro1x battery, from what we've been told by Casey. 1 Quote Link to post Share on other sites
sequestris 710 Posted March 4, 2023 Share Posted March 4, 2023 2 hours ago, Hook said: I believe they have Pro1 parts in London while all the Pro1x IGG stuff comes from Hong Kong. So I think if you set up a battery purchase directly with the London office, you will probably get it. The Pro1 battery is different than the Pro1x battery, from what we've been told by Casey. I still want it deducted from what they owe me 😄 Quote Link to post Share on other sites
Hook 3,318 Posted March 4, 2023 Share Posted March 4, 2023 1 hour ago, sequestris said: I still want it deducted from what they owe me 😄 I don't blame you. 🙂 Quote Link to post Share on other sites
