lockguy79 0 Posted September 19, 2023 Share Posted September 19, 2023 Hello, so I have a pro1 that came with linageos I tried to use ubports and now my phone is stuck in fastboot mode. When i plug it in to my laptop (running ubuntu 22) the screen will change from the start screen to the fxtec logo and in tiny leters in the upper right hand corner words that say to press any key to shut down. When I press a key the phone cycles for a couple of seconds and goes back to the fxtec logo screen. (on the bottom of the screen it said ubuntu touch) I used Toms restore tool and now it says andriod at the bottom instead of ubuntu touch. no matter what I do I cant get the phone to do anything different. If I run fastboot devices in the terminal it will see and list my phone and I can run fastboot reboot and the phone will reboot but it goes back to the fxtec logo screen. I think I might have deleted the partitions or something. I am stuck and I just dont know whatelse to do. at this point I just want the phone to work again. Thanks for your time. Quote Link to post Share on other sites
Hook 3,293 Posted September 19, 2023 Share Posted September 19, 2023 I'm not sure who Nelson is, but I removed your email as it is not wise to post your email addy in a forum post (invitation to spammers). People can answer you here or in a private message. :) Quote Link to post Share on other sites
EskeRahn 5,593 Posted September 19, 2023 Share Posted September 19, 2023 If your aim is to restore, and you have given up trying to get any data on it, you might start here: Quote Link to post Share on other sites
PoongZY 15 Posted September 19, 2023 Share Posted September 19, 2023 My experience on this. You need to flash back to stock before flashing Ubuntu touch. But mine is a pro1-x 1 Quote Link to post Share on other sites
lockguy79 0 Posted September 24, 2023 Author Share Posted September 24, 2023 Thanks for responding yall. There was no data on it. Im just trying to get to a usable state again. Hook, thanks for the tip. Quote Link to post Share on other sites
