pro1xsux 0 Posted August 21, 2024 Share Posted August 21, 2024 My Pro 1 X device keeps turning off while in use. I've tried factory resetting it while using stock Android, and even installed LineageOS 21, but nothing works. Is there a way to check the crash log to see which app is causing the crash? Quote Link to post Share on other sites
CornholioGSM 370 Posted August 21, 2024 Share Posted August 21, 2024 hmmm maybe logcat app ? Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 21, 2024 Share Posted August 21, 2024 In other threads some were talking temperature issues. Could that be relevant for you? That is if it does not throttle down sufficiently to prevent itself from overheating. Quote Link to post Share on other sites
foxfreejack 60 Posted August 21, 2024 Share Posted August 21, 2024 Another possibility is a bad or worn out battery. Under load battery voltage goes too low and the device just turns off. Quote Link to post Share on other sites
CornholioGSM 370 Posted August 21, 2024 Share Posted August 21, 2024 2 hours ago, foxfreejack said: Another possibility is a bad or worn out battery. Under load battery voltage goes too low and the device just turns off. yesss for me it looks too like battery problem and not los problem. Quote Link to post Share on other sites
