Kzin 33 Posted September 15, 2024 Share Posted September 15, 2024 (edited) As the title suggests, I am unable to send or receive SMS messages. It just stopped a few days ago. it appears to send them, but they are not. Calls are working fine. I have tried the following actions to get it to go: I have downgraded to lineage-21.0-20240615-nightly-pro1-signed, (this fixed the camera, but not the SMS issue) I removed the sim and put it back. I put my SIM in another phone, SMS is working there. Is it possible I have tweeked a setting? Edited September 15, 2024 by Kzin Quote Link to post Share on other sites
Kzin 33 Posted September 15, 2024 Author Share Posted September 15, 2024 I just tried the SIM back in the Pro 1, and now SMS works... 2 Quote Link to post Share on other sites
EskeRahn 5,598 Posted September 15, 2024 Share Posted September 15, 2024 sms/mms work fine on both my Pro1 on stock and Liineage, so hard to say what is not woking 1 Quote Link to post Share on other sites
Kzin 33 Posted September 15, 2024 Author Share Posted September 15, 2024 I don't under stand it either. Main thing is it's working now. I have to assume that putting my SIM in the other phone, reset something, so it worked when I put it back in the Pro1. 2 Quote Link to post Share on other sites
Kzin 33 Posted October 31, 2024 Author Share Posted October 31, 2024 This is back now and above fix is not helping. we are in a low signal area and the phone used to give an error (cannot send etc) but now they appear to send, but are not received. Is there a debug/logging mode for SMS? Quote Link to post Share on other sites
Hook 3,313 Posted October 31, 2024 Share Posted October 31, 2024 Are you in the US and are you on Verizon? I ask because this was the problem I had when I used to try to have my Pro 1 on Verizon. It would work fine and then some aspect of the SMS would fail. Then it would come back without my being able to explain how and then, after a while it would break again. I gave up and put my Pro 1 on T-Mobile. Have never had SMS fail. This was back a couple of years before Verizon became so aggressive about whitelisting. Quote Link to post Share on other sites
Kzin 33 Posted November 1, 2024 Author Share Posted November 1, 2024 4 hours ago, Hook said: Are you in the US and are you on Verizon? No, 2degrees in New Zealand Quote Link to post Share on other sites
--- 129 Posted November 2, 2024 Share Posted November 2, 2024 On 11/1/2024 at 2:59 PM, Kzin said: No, 2degrees in New Zealand I'm on 2degrees (Welcome Bay) on a Pro1X running LineageOS, and I've had missing SMS for the last 2 or 3 weeks. Discussions with Mrs MonCon revealed that some texts had disappeared into the ether, apparently delivered from my end, never received to her end. Like you, I put my sim into a backup phone and it worked, then back into my PrawnX and it worked. It's just started playing up again. On Friday I sent Mrs MC a few texts from the dining room to the lounge, and when we compared notes, again a few missing. Don't think I've been missing any incoming, but I'll ask around, and no other connectivity issues in 2 years. I've looked at the generic recommended settings, APN and the like, and all looks good. Not that I've even been tinkering in the first place. I would suggest maybe getting a Vodafone (One) prepay in your 2nd slot, or maybe trying your 2degrees SIM in your 2nd slot and seeing how you go. Maybe 2degrees are turning into the Kiwi Verizon. 1 1 Quote Link to post Share on other sites
Kzin 33 Posted November 4, 2024 Author Share Posted November 4, 2024 On 11/2/2024 at 9:32 PM, MonCon said: I'm on 2degrees (Welcome Bay) on a Pro1X running LineageOS, and I've had missing SMS for the last 2 or 3 weeks. Discussions with Mrs MonCon revealed that some texts had disappeared into the ether, apparently delivered from my end, never received to her end. Like you, I put my sim into a backup phone and it worked, then back into my PrawnX and it worked. It's just started playing up again. On Friday I sent Mrs MC a few texts from the dining room to the lounge, and when we compared notes, again a few missing. Don't think I've been missing any incoming, but I'll ask around, and no other connectivity issues in 2 years. I've looked at the generic recommended settings, APN and the like, and all looks good. Not that I've even been tinkering in the first place. I would suggest maybe getting a Vodafone (One) prepay in your 2nd slot, or maybe trying your 2degrees SIM in your 2nd slot and seeing how you go. Maybe 2degrees are turning into the Kiwi Verizon. I'm so glad its not me going nuts! I just tried again and they seem to be sending now. but had several days where nothing would go. Unfortunately I'm looking at getting another phone. We are just out of CHCH and signal is bad, would be good to have Wifi Calling, as well as txts that send reliably. Quote Link to post Share on other sites
