CornholioGSM 369 Posted November 17, 2024 Share Posted November 17, 2024 (edited) Hello, it looks like LineageOs 22.0 from #npjohnson is out 🙂 As always (i mean) updates will be every month. https://updater.oddsolutions.us/devices/pro1/builds So official will be within two months. Maybe will be good to test it and post bugs to npjohnson before official los release because npjohnson is official los developer 🙂  * i will test it within few days  Edited December 21, 2024 by CornholioGSM 1 4 Quote Link to post Share on other sites
CornholioGSM 369 Posted November 18, 2024 Author Share Posted November 18, 2024 So dirty flashed without wipe from last official 21 to this 22. First flashed recovery (boot) and then lineage. ***gapps are included inside OddSolutions builds! All without problem - phone boots normally without any error. Then was only needed to reflash magisk for root access. Â Â 2 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 18, 2024 Share Posted November 18, 2024 Just curious, have they fixed the issue where we could no longer select multiple keyboard layouts to switch between? Quote Link to post Share on other sites
CornholioGSM 369 Posted November 18, 2024 Author Share Posted November 18, 2024 1 hour ago, EskeRahn said: Just curious, have they fixed the issue where we could no longer select multiple keyboard layouts to switch between? if you mean in hw keyboard settings, then you can select only one 😞 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 18, 2024 Share Posted November 18, 2024 1 hour ago, CornholioGSM said: if you mean in hw keyboard settings, then you can select only one 😞 Thanks ;( Quote Link to post Share on other sites
CornholioGSM 369 Posted November 18, 2024 Author Share Posted November 18, 2024 (edited) 7 hours ago, CornholioGSM said: if you mean in hw keyboard settings, then you can select only one 😞  Edited November 18, 2024 by CornholioGSM Quote Link to post Share on other sites
CornholioGSM 369 Posted November 18, 2024 Author Share Posted November 18, 2024 8 hours ago, EskeRahn said: Just curious, have they fixed the issue where we could no longer select multiple keyboard layouts to switch between? Have you asked by @npjohnson ? Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 20, 2024 Share Posted November 20, 2024 On 11/18/2024 at 11:34 PM, CornholioGSM said: Have you asked by @npjohnson ? I hardly recall, it has been missing for so long.... I reported it fixed herehttps://community.fxtec.com/topic/3557-lineageos-191-official-release-for-pro1/?tab=comments#comment-61182 But it was broken again later.... Quote Link to post Share on other sites
CornholioGSM 369 Posted November 30, 2024 Author Share Posted November 30, 2024 (edited) ***BUG found. I am able to enable wifi hotspot...but i am unable to turn hotspot off. Settings crashes and is needed reboot. Edited November 30, 2024 by CornholioGSM 1 1 Quote Link to post Share on other sites
CornholioGSM 369 Posted December 22, 2024 Author Share Posted December 22, 2024 Lineageos was renamed from 22.0 to 22.1. Last update from December 21. must be installed via adb sideload...but dirty flash works fine and all data and settings still. After install is needed to renew magisk. Minimal gapps are still included in oddsolutions version of lineage. (google play&services, messages and phone) 1 2 Quote Link to post Share on other sites
