phirephoto 0 Posted April 18, 2025 Share Posted April 18, 2025 I have a F(x)tec Pro-1 X QX1050 It boots to I believe the fastboot screen. I've tried each of the options - Start, restart bootloader, recovery mode, Boot to FFBM and Boot to QMMI. Each option just essentiallyh reboots the phone back to that screen. It's not recognzied via ADB Devices Any suggestions on what else to try? Tried a few cables, a few computers. Thanks. Quote Link to post Share on other sites
phirephoto 0 Posted April 22, 2025 Author Share Posted April 22, 2025 Any suggestions? Quote Link to post Share on other sites
Hook 3,339 Posted April 22, 2025 Share Posted April 22, 2025 I don't know if I have a suggestion, but I suspect more information is needed. Is this a Pro1x that was formerly working ok and this just suddenly happened? Or did it do this when you got it. If the former, what kinds of things were you doing with the phone? Is it Stock Android or did you flash some other ROM? Anything you can tell people will help them decide if they know something you can try. 1 Quote Link to post Share on other sites
phirephoto 0 Posted April 23, 2025 Author Share Posted April 23, 2025 2 hours ago, Hook said: I don't know if I have a suggestion, but I suspect more information is needed. Is this a Pro1x that was formerly working ok and this just suddenly happened? Or did it do this when you got it. If the former, what kinds of things were you doing with the phone? Is it Stock Android or did you flash some other ROM? Anything you can tell people will help them decide if they know something you can try. I got it second hand. Was working - I was trying to flash the Ubuntu touch and it crashed during the flash. Sorry don't recall error. Was using UBPorts installer 😞 Quote Link to post Share on other sites
phirephoto 0 Posted May 9, 2025 Author Share Posted May 9, 2025 Any other suggestions? Do I have a paperweight? Quote Link to post Share on other sites
EskeRahn 5,602 Posted May 9, 2025 Share Posted May 9, 2025 USUALLY the problems people experiences with fastboot is related to the communication with the watch. Either cable, port or driver. Silly as it may sound on Windows11, a 'newer' USB3 port might cause problems. On my Lenovo X1 Yoga gen 6 (20XY), I can not get fastboot to work directly. But if I use an old usb2 hub, things works fine. It also works fine if I go via my thunderbolt 4 docking, and a USB3 port on that. AFAIK, there are fewer issues if the machine is on LINUX. You might also try from an old PC with USB2 ports only. Usually it is not super picky on the cable, but try swapping that also if a different port does not help. And then finally the more complex is that not all drivers works equally well, and that can be a hassle. (Note that on my pc, a direct cable works fine with ADB or with file-transfer, it is fastboot that is quite picky) - my guess would be a handshaking issue in fastboot for Windows, where it fails if it gets the answer too fast) 2 Quote Link to post Share on other sites
phirephoto 0 Posted June 8, 2025 Author Share Posted June 8, 2025 So I was able to get it to be recognized in .. QFIL mode? But it fails:: 2025-06-07 17:02:46.107 13: C:\phone\Release_SM6115_S701_gms_V2.1.2_20220707-1501_user\prog_firehose_ddr.elf 2025-06-07 17:02:46.107 2025-06-07 17:02:46.108 17:02:46: ERROR: function: sahara_rx_data:276 Unable to read packet header. Only read 0 bytes. 2025-06-07 17:02:46.108 2025-06-07 17:02:46.108 17:02:46: ERROR: function: sahara_main:982 Sahara protocol error 2025-06-07 17:02:46.109 2025-06-07 17:02:46.109 17:02:46: ERROR: function: main:320 Uploading Image using Sahara protocol failed 2025-06-07 17:02:46.110 2025-06-07 17:02:46.110 2025-06-07 17:02:46.111 Download Fail:Sahara Fail:QSaharaServer Fail:Process fail 2025-06-07 17:02:46.111 Finish Download Quote Link to post Share on other sites
EskeRahn 5,602 Posted June 8, 2025 Share Posted June 8, 2025 Did you try with an OLD computer or one on Linux? As I explained usb-3 under windows can be problematic. If no data-communication at all can be established there could be an electric problem, e.g. dirt in the plug, or a plug that has gone partly loose Quote Link to post Share on other sites
Đầńΐǽ𝖑 0 Posted July 15, 2025 Share Posted July 15, 2025 (edited) I've had this [almost] exact problem with my F(×)Tec Pro 1 back since mid November of 2022. After getting the phone brand new and using it for 2 & 1/2 years (yes there were a few accidental phone drops from small heights that produced only miniscule aesthetic scuffs on the corners): it was still in near perfect condition minus only one of the symbol switching keys not working on the keyboard. So that's some context, yet other than that it was in full perfect working order (in a condition of slight use) without any screen cracks nor damage (aside from what's aforementioned). Took it to cell phone repair shop after cell phone repair shop in North America (between some cities in Canada & the USA) to try to get it diagnosed then fixed. Even in the very international city of Toronto (& its GTA) multiple repair shops simply couldn't wrap their heads around the "complex" UK technology within the phone. So they said without knowing much on the phone's unique British assembly, that all they could do to get it operable was as follows: a complete memory wipe from a full reset via unlocking the phone; to which I declined (not wanting to lose what data was stored on the device. If you're backed up this might be the solution for you. At any rate after losing hope for a couple years that I could ever get past this reset / restarting screen [QFIL Mode as you put it(?)], I only just very recently exhumed the phone and contacted the customer service email F(×)Tec provided @ the time of shipping — some 9 months later (blame The Pandemic) after it had been pre-ordered. So just the other day I sent F(×)Tec a couple emails about the issue, thus whence they respond; back I'll forward their response here in an attempt to help us both work through this seemingly frustratingly Impossible issue. Kindest regards, –Đầńΐǽ𝖑 P.S. if you are able to get any troubleshooting screens to come up again please take pictures of them and upload them here if you can; as mine just constantly reboots and that page doesn't even come up anymore. Hopefully we can all put our minds together to shed this paperweight; God willing. Edited July 15, 2025 by Đầńΐǽ𝖑 Looks like they: "All-Your-Base-Are-Belonged-To-Us" us both. Quote Link to post Share on other sites
