kashif 350 Posted August 29, 2019 Share Posted August 29, 2019 Hi Guys Just wanted to ask your expert opinion. Pro1 supports only microSD card. but all the cards that you can find now a days seems to be micro SDHD or micro SDXC. so my understanding is the SDHD and SDXC are not compatiable with SD. how can we find microSD card for pro1, a decent size like 256gb or 512gb Quote Link to post Share on other sites
EskeRahn 5,598 Posted August 29, 2019 Share Posted August 29, 2019 It is inaccurately just called microSD, see e.g. this for details. But I guess that if you insert an old microSD-card it will work too. Quote Link to post Share on other sites
Hook 3,313 Posted August 29, 2019 Share Posted August 29, 2019 Hi Guys Just wanted to ask your expert opinion. Pro1 supports only microSD card. but all the cards that you can find now a days seems to be micro SDHD or micro SDXC. so my understanding is the SDHD and SDXC are not compatiable with SD. how can we find microSD card for pro1, a decent size like 256gb or 512gb Most spec sheets use "MicroSD" loosely. SDHD and SDXC distictions are related to capacity. The Pro1 spec sheet says it takes cards up to 2TB, which means that it must take SDHC and SDXC cards. Quote Link to post Share on other sites
netman 1,424 Posted August 29, 2019 Share Posted August 29, 2019 It most definitely supports micro- SDHC and SDXC, that's the only way to support the claimed 2tb size. SDHC and SDXC are SD cards too, but not SDSC (aka "normal SD card" that goes up to 2gb only). Quote Link to post Share on other sites
kashif 350 Posted August 29, 2019 Author Share Posted August 29, 2019 Thanks alot all of you to make it clear for me :) Quote Link to post Share on other sites
