Slion 1,201 Posted March 12, 2020 Share Posted March 12, 2020 Been using Pro1 for over 6 weeks and rotation only got stuck 3 times. Funny enough those 3 times happened within 4 days. It looks like there is indeed a problem but luckily for me it does not trigger so often here. I had to reboot the phone to get it working again. Quote Link to post Share on other sites
EskeRahn 5,596 Posted March 12, 2020 Share Posted March 12, 2020 3 hours ago, Slion said: Been using Pro1 for over 6 weeks and rotation only got stuck 3 times. Funny enough those 3 times happened within 4 days. It looks like there is indeed a problem but luckily for me it does not trigger so often here. I had to reboot the phone to get it working again. Next time try launching a program that ignores your auto-rotate setting, And rotate the Pro1 back and forth within the app. e.g. the snapdragon camera app or AndroSensor. It usually solves it for me. 2 Quote Link to post Share on other sites
Slion 1,201 Posted March 18, 2020 Share Posted March 18, 2020 On 3/12/2020 at 9:27 AM, EskeRahn said: Next time try launching a program that ignores your auto-rotate setting, And rotate the Pro1 back and forth within the app. e.g. the snapdragon camera app or AndroSensor. Indeed, just ran across that problem again and launching the camera app saved me a reboot. 1 Quote Link to post Share on other sites
MickH 212 Posted March 19, 2020 Author Share Posted March 19, 2020 I'm guessing it could be some apps that are misbehaving. I'm still getting the "Recent Items" screen popping up when I open the slider and the only way to clear it is to restart. I'm beginning to suspect K-9 Mail is one of the apps responsible for that. Without root there's no way to find out what's still running hidden in the background. 1 Quote Link to post Share on other sites
Slion 1,201 Posted June 12, 2020 Share Posted June 12, 2020 That's now happening multiple times a day. A reboot did not help, most annoying. 1 Quote Link to post Share on other sites
Slion 1,201 Posted June 12, 2020 Share Posted June 12, 2020 (edited) On top of the rotation getting stuck it also keeps bringing up the virtual keyboard even though the physical keyboard is open. It's been working fine for like 6 months but now really acting up. I'm starting to understand the frustrations other users have expressed on those forums. It has something to do with the opening and closing of the keyboard. Maybe I can implement another workaround in Fx Service. Edited June 12, 2020 by Slion 2 Quote Link to post Share on other sites
Slion 1,201 Posted June 13, 2020 Share Posted June 13, 2020 It's getting stuck every time I close the keyboard. 1 Quote Link to post Share on other sites
Slion 1,201 Posted June 13, 2020 Share Posted June 13, 2020 I did my homework and I have good hope I could implement a workaround in Fx Service. Just have to find time to try it out. See:https://github.com/Slion/FxService/issues/2https://slions.net/resources/fx-service.8/ 1 Quote Link to post Share on other sites
Slion 1,201 Posted July 3, 2020 Share Posted July 3, 2020 On 6/13/2020 at 9:01 AM, Slion said: I did my homework and I have good hope I could implement a workaround in Fx Service. Just have to find time to try it out. See:https://github.com/Slion/FxService/issues/2https://slions.net/resources/fx-service.8/ Hopefully that should fix it: 1 Quote Link to post Share on other sites
Slion 1,201 Posted October 8, 2020 Share Posted October 8, 2020 On 6/12/2020 at 3:22 PM, Slion said: On top of the rotation getting stuck it also keeps bringing up the virtual keyboard even though the physical keyboard is open. I'm guessing this was the case cause I must have tried to disable Settings > Slider Landscape orientation lock . Quote Link to post Share on other sites
