Slion 1,201 Posted September 27, 2020 Share Posted September 27, 2020 (edited) FxTec Pro1 has a special Settings section called Slider. One of those settings called "Landscape orientation lock" is badly broken both at the user level and at the system and application developer level. At the user level: When enabled it does not always switch to landscape when the keyboard is opened. When disabled the software keyboard pops up even when the keyboard is opened. At the system and developer level: When enabled all seems to be working as expected and apps get a configuration changed notification whenever the keyboard opens or closes. When disabled the system does not change the configuration that's telling apps whether or not the keyboard is opened. Apps can't tell if the keyboard is opened. It's always reported as closed. Your best bet is to make sure that settings option is always enabled. Could you guys confirm you observe the same behaviour? I'm thinking it was not always like that on my phone and maybe some underlying settings got messed up at some point somehow.@ErikAny chance of getting this sorted out in an up coming software releases? Edited October 8, 2020 by Slion Quote Link to post Share on other sites
Slion 1,201 Posted September 28, 2020 Author Share Posted September 28, 2020 12 hours ago, Slion said: Could you guys confirm you observe the same behaviour? I'm thinking it was not always like that on my phone and maybe some underlying settings got messed up at some point somehow. Same issue on a new phone. Disabling landscape orientation lock is indeed badly broken. Quote Link to post Share on other sites
