Flo 22 Posted January 25, 2020 Share Posted January 25, 2020 I can't decide if I like it since it adds character or if it is mildly infuriating and will keep me up at night. I guess it would be an easy fix that I could do myself but then I have to take the stickers off the screws. It also does not effect the usage of the keyboard and everyone that I showed it found it hilarious 😄 4 8 Quote Link to post Share on other sites
netman 1,424 Posted January 25, 2020 Share Posted January 25, 2020 3 minutes ago, Flo said: I can't decide if I like it since it adds character or if it is mildly infuriating and will keep me up at night. In my opinion it adds rotates character. I had no idea the keycaps were individual separate things, that's quite nice actually. 4 Quote Link to post Share on other sites
VaZso 1,999 Posted January 25, 2020 Share Posted January 25, 2020 16 minutes ago, Flo said: I guess it would be an easy fix that I could do myself but then I have to take the stickers off the screws. It also does not effect the usage of the keyboard and everyone that I showed it found it hilarious 😄 I thought keyboard mat is in one piece but maybe it isn't. Hmm, if it is in one piece, F(x)tec may send a replacement part and maybe replacement stickers, but... ...in the world of money, I think these special differences make it worth even more. I am not sure about technical devices though. 2 Quote Link to post Share on other sites
Noir 114 Posted January 25, 2020 Share Posted January 25, 2020 (edited) Will give you mine for exchange, it´s a one-of-a-kind. I would not recommend to take it apart to peel of the button and reseat it. As far as I can tell, single Buttons are not meant to be replaced/torn off. Edited January 25, 2020 by Noir 3 Quote Link to post Share on other sites
Flo 22 Posted January 25, 2020 Author Share Posted January 25, 2020 38 minutes ago, Noir said: Will give you mine for exchange, it´s a one-of-a-kind. Thanks for the offer but I think I will keep it like this 🙂 I wish the shortcuts could also be used for other things besides launching apps. Would love to map it to rotating the screen. 2 Quote Link to post Share on other sites
Parhelion 114 Posted January 25, 2020 Share Posted January 25, 2020 This one would be the perfect device for a lawyer. Legal sections are more important than numbers 😉 1 3 Quote Link to post Share on other sites
david 929 Posted January 26, 2020 Share Posted January 26, 2020 (edited) If it was me, I would ask them to send you a corrected keyboard and then you'll have a spare in case the original one wears out or the letters wear off. That seems fair, since you do have a defect. However, I'd use it and think fondly of it, as others have said, by being unique and also a reminder of the special nature of the phone, in general. And each time you see the upside down 3, it will be a reminder for you to send negative karma to Steve Jobs, wherever he may be, for putting all of us keyboard lovers in this minority situation. 😉 Edited January 26, 2020 by david 3 Quote Link to post Share on other sites
