sequestris 710 Posted January 27, 2020 Share Posted January 27, 2020 Can someone point me to the APN set up link/instructions? Why is there no shutter sound with the camera? It's turned on and all the other sounds/notifications work. I have tried searching the forum to find this, but is there a way/mod/app to get back my old nav buttons at the bottom Quote Link to post Share on other sites
EskeRahn 5,593 Posted January 27, 2020 Share Posted January 27, 2020 1 - carrier dependent 2 - known bug 3 - in system, gestures turn OFF Swipe up on home Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 35 minutes ago, EskeRahn said: 1 - carrier dependent 2 - known bug 3 - in system, gestures turn OFF Swipe up on home 3) Thank you SO much @EskeRahn Can anyone with T-Mobile help me with #1? Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 4) Is there any way to revert to classic icons without the white circle around them? Quote Link to post Share on other sites
EskeRahn 5,593 Posted January 28, 2020 Share Posted January 28, 2020 3 minutes ago, sequestris said: 4) Is there any way to revert to classic icons without the white circle around them? Only partly pure stock, the icon uglification is a fairly new google 'feature'. Hold anywhere in the background on hte desktop, Home Settings, Change Icon shape. Some launchers allow you to get real icons back. Overruling Google. 1 Quote Link to post Share on other sites
david 929 Posted January 28, 2020 Share Posted January 28, 2020 2 hours ago, sequestris said: Can anyone with T-Mobile help me with #1? https://www.t-mobile.com/support/devices/not-sold-by-t-mobile/byod-t-mobile-data-and-apn-settings 1 Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 25 minutes ago, david said: https://www.t-mobile.com/support/devices/not-sold-by-t-mobile/byod-t-mobile-data-and-apn-settings Thank you. I got it to receive but sending is still failing :/ Quote Link to post Share on other sites
david 929 Posted January 28, 2020 Share Posted January 28, 2020 2 minutes ago, sequestris said: Thank you. I got it to receive but sending is still failing :/ Sending and receiving what? Text messages? Instant messages? Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 Texts are fine. MMS doesn't work. It shows that it has sent, but the other device does not receive them. Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 Rephrase: Incoming MMS works, outgoing does not. Quote Link to post Share on other sites
david 929 Posted January 28, 2020 Share Posted January 28, 2020 2 minutes ago, sequestris said: Rephrase: Incoming MMS works, outgoing does not. Are you sending to someone else on T-Mobile? Maybe try multiple people to see if it is some oddity with the from/to provider. There are also settings for MMS in a lot of texting apps, so maybe there is a setting that needs to be messed with. I won't be able to test mine for texting until sometime in the next week, most likely, since I only have an non-activated SIM of the right size for the Pro1 and need to leave my other bigger SIM active in my old phone until I make the final leap to using the Pro1 fully. Quote Link to post Share on other sites
david 929 Posted January 28, 2020 Share Posted January 28, 2020 Can you send screenshots of the APN screen (or multiple if it is long and scrolls)? Quote Link to post Share on other sites
EskeRahn 5,593 Posted January 28, 2020 Share Posted January 28, 2020 On outgoing MMS, make sure to test with something very simple like emoji, or a very reduced image. Some have a low limit on image size, and do NOT offer to compress the image, but expects that you or your mms app handles that. 2 Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 @EskeRahn Okay, I'll try that.@david Gimme a few. Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 (edited) @EskeRahn and @david Thanks for all your help. I had a ginasty headache last night and was just getting frustrated. I had taken screenshots of the APN settings that you had requested and on a whim I sent them to my other phone and sending them as MMS worked. Then I did a reverse to test receipt and it received just fine too. No clue.@davidThanks for the link for the TPU bumper; I ordered one. Edited January 28, 2020 by sequestris 1 Quote Link to post Share on other sites
EskeRahn 5,593 Posted January 28, 2020 Share Posted January 28, 2020 10 minutes ago, sequestris said: @EskeRahn and @david Thanks for all your help. I had a ginasty headache last night and was just getting frustrated. I had taken screenshots of the APN settings that you had requested and on a whim I sent them to my other phone and sending them as MMS worked. Then I did a reverse to test receipt and it received just fine too. No clue.@davidThanks for the link for the TPU bumper; I ordered one. My guess is the size. It is not uncommon with a limit of 300KB or even lower. So try sending small images. Some message apps like e.g. Textra allows you to control the limit, and compress if needed. This might render the result useless as details gets lost, but at the least it gets through. And different carriers have different limits. And at the least in theory could use different limits to other users in their own net and forwarding them to other nets. You might try to experiment sending MMS to a mail-address also 2 Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 I have found that when I pop over to gmail to email the pic, all is shiny. Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 14 hours ago, EskeRahn said: Only partly pure stock, the icon uglification is a fairly new google 'feature'. Hold anywhere in the background on hte desktop, Home Settings, Change Icon shape. Some launchers allow you to get real icons back. Overruling Google. I tried 4 different launchers and they all choked. Upside is Google refunded. 1 Quote Link to post Share on other sites
EskeRahn 5,593 Posted January 28, 2020 Share Posted January 28, 2020 4 minutes ago, sequestris said: I have found that when I pop over to gmail to email the pic, all is shiny. (I meant try to send it as a MMS from your preferred sms/mms app to an e-mail address) Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 That's what I was doing - the sendto gmail. Quote Link to post Share on other sites
EskeRahn 5,593 Posted January 28, 2020 Share Posted January 28, 2020 3 minutes ago, sequestris said: That's what I was doing - the sendto gmail. Ah I see. And in the mail recieved ithe sender looks like an mms and not a normal mail? (Please note reply FROM mail TO MMS seldom works) You could experiment to find the limit the carrier accepts as incoming. The next is what their limit is for outgoing to various recipient networks.... Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 3 minutes ago, EskeRahn said: Ah I see. And in the mail recieved ithe sender looks like an mms and not a normal mail? (Please note reply FROM mail TO MMS seldom works) You could experiment to find the limit the carrier accepts as incoming. The next is what their limit is for outgoing to various recipient networks.... I have never done the reply FROM thing so I think that is a non-issue for me. Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 5) How come the alert tone/volume is wake-the-dead loud even though I have all the volumes set for 20%? 1 Quote Link to post Share on other sites
peter3 10 Posted January 28, 2020 Share Posted January 28, 2020 Thanks for the pointer at removing gesture support, I'm not a huge fan of Android 9 so far. After turning off the assistant and removing gesture support it's a tad more usable. 1 1 Quote Link to post Share on other sites
sequestris 710 Posted January 28, 2020 Author Share Posted January 28, 2020 30 minutes ago, EskeRahn said: My guess is the size. It is not uncommon with a limit of 300KB or even lower. So try sending small images. I use Contacts+ and love it. I changed the limiting option and now all size MMSes go through :) 2 Quote Link to post Share on other sites
