marmistrz 93 Posted June 15, 2020 Share Posted June 15, 2020 (edited) Hi, I started playing out with my new Pro1 and the bootloader is behaving a very weird way. I boot into fastboot mode, connect the phone to the computer. Then I run`sudo fastboot devices`. Sometimes the command succeeds and the device is listed by fastboot, but usually fastboot will not list any devices and the Pro1 will just display "Press any key to shutdown" I'm running Arch Linux, fastboot version 30.0.2-6538114 from android-sdk-platform-tools. The same happens with fastboot version 30.0.0-2 from android-tools. (checked on two computers) The issue seems specific to the Pro1, because it doesn't occur with OnePlus3 with the same setup. What's going on with fastboot? Edited June 15, 2020 by marmistrz Quote Link to post Share on other sites
tdm 2,322 Posted June 16, 2020 Share Posted June 16, 2020 That is very strange. I've never seen anything like that. Out of curiosity, I searched the bootloader source code for that string, and found ... nothing. 😕 If you send me a wireshark dump of the usb traffic, maybe I can find a clue? 1 Quote Link to post Share on other sites
marmistrz 93 Posted June 16, 2020 Author Share Posted June 16, 2020 (edited) Thanks a lot for the suggestion. The USB dump is attached. 66 is the last packet before connecting with USB. 142 is the last packet before the fastboot command. I guess the bootloader has problems with USB autosuspend. When I played around, and executed the fastboot command immediately, it worked. If I kept executing it again and again, it was all ok, but if I waited for a longer while between the fastboot commands, the bootloader would enter the "Press any key to shutdown" state. I disabled USB autosuspend with echo -1 > /sys/module/usbcore/parameters/autosuspend and I can confirm that the problem is gone with autosuspend disabled. EDIT: However, flashing the LineageOS boot image is impossible even with autosuspend disabled. The command sudo fastboot flash boot_a lineage-16.0-pro1-test13-boot.img just does nothing. See the new USB dump 128 is the last packet after fastboot devices 165 is the last packet during fastboot flash. Afterwards I shut down the bootloader using the volume/power keys on the device. dumpusb2.pcapng dump-flash_a.pcapng Edited June 16, 2020 by marmistrz Quote Link to post Share on other sites
acrux 56 Posted June 16, 2020 Share Posted June 16, 2020 Does Arch Linux forces you to run fastboot with sudo? Wasn't it even not recommended? Quote Link to post Share on other sites
marmistrz 93 Posted June 16, 2020 Author Share Posted June 16, 2020 (edited) That's a good point. After installing android-udev I can run fastboot without sudo, but the problem with `fastboot flash` persists. Edited June 16, 2020 by marmistrz Quote Link to post Share on other sites
tdm 2,322 Posted June 16, 2020 Share Posted June 16, 2020 5 hours ago, marmistrz said: Thanks a lot for the suggestion. The USB dump is attached. Well, I'm afraid I don't know anything about the USB low level stuff. I only know the various protocols involved, which use bulk transfers. In your first capture, there are no bulk transfers at all. So everything that is happening is low level. In your second capture, I see the host sending a request (packet 157, "getvar:has-slot:boot_a"). The phone does not respond at all. I'm working with another user who is seeing a similar issue with EDL. Not sure if they are related, but it seems like it may be. My current theory is that the host is incompatible with the phone in some way. Can you perhaps try different host ports? For example, avoid USB 3.0 ports, try with/without a hub, and even try different hosts? Quote Link to post Share on other sites
marmistrz 93 Posted June 16, 2020 Author Share Posted June 16, 2020 (edited) I believe this one should be 2.0. See the attached dump. 70 before fastboot devices, 98 is before fastboot flash. The problem is the same (USB autosuspend is still disable, because fastboot devices failed on all ports). I have two root hubs on my laptop. I have also tried on another, older Dell laptop. Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 003: ID 0bda:5520 Realtek Semiconductor Corp. Integrated_Webcam_HD Bus 001 Device 004: ID 0cf3:e009 Qualcomm Atheros Communications Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub I tested one more thing on 2.0. I did fastboot flashing lock, but chose "do not lock the bootloader" with the volume keys on the device. fastboot output was: $ fastboot flashing lock FAILED (Status read failed (No such device)) fastboot: error: Command failed notlock.pcapng contains the USB dump, 65 was before connecting the device, 82 was before not confirming the lock. I think I had a similar "failed" message when unlocking the bootloader. dumpflash2.0.pcapng notlock.pcapng Edited June 16, 2020 by marmistrz Quote Link to post Share on other sites
marmistrz 93 Posted June 17, 2020 Author Share Posted June 17, 2020 (edited) I managed to flash the LineageOS recovery! I found some USB hub, connected it to the USB 3.0 port, connected the device to the hub and fastboot flash worked. I have absolutely no idea why, but here's the USB dump. Edited June 19, 2020 by marmistrz added the usb dump 1 1 Quote Link to post Share on other sites
EskeRahn 5,596 Posted June 18, 2020 Share Posted June 18, 2020 On 6/17/2020 at 11:50 AM, marmistrz said: I managed to flash the LineageOS recovery! I found some USB hub, connected it to the USB 3.0 port, connected the device to the hub and fastboot flash worked. I have absolutely no idea why, but you can find the attached USB dump. (will be uploaded later today) We have had other reports that people have better luck connecting to a 2.0 than a 3.0 port. Quote Link to post Share on other sites
marmistrz 93 Posted June 19, 2020 Author Share Posted June 19, 2020 For me neither 2.0 nor 3.0 worked. I uploaded the USB dump in my previous post. Quote Link to post Share on other sites
