dicer 36 Posted August 10, 2020 Share Posted August 10, 2020 Did the same as @DieBruineand can also confirm that VoLTE works for me. I'm on o2 Germany. Wifi calling also works. Both on lineage. No icons are being displayed for either though. There is a Lineage pull request that is adding those icons: https://review.lineageos.org/c/LineageOS/android_frameworks_base/+/279554 2 Quote Link to post Share on other sites
D1ggs 141 Posted August 22, 2020 Share Posted August 22, 2020 (edited) Zero issues with my pro 1 on versions volte. Once it was set it hasn't come undone. Been going on about 3 months now without issue. This has been with stock and updated as fixes are made available. Edited August 22, 2020 by D1ggs 2 Quote Link to post Share on other sites
fashion_m 5 Posted November 9, 2020 Share Posted November 9, 2020 (edited) Hi, I use Fxtec Pro1 with the Bulgarian mobile operator Vivacom. "VoLTE provisioned" switch is grayed-out and turned off. I called the support and they told me that VoLTE is enabled for a whitelisted set of popular phones only. The guy sent a message to the technical team about my phone, but it's not guaranteed that Pro1 will be whitelisted neither I'll be contacted at all. I am in areas of bad coverage and the phone frequently switches from 4G to 3G/2G and my internet becomes slow, so I explicitly set network mode to LTE, because weak LTE signal delivers faster internet than 3G with better signal. The bad thing is that I cannot make and receive calls, and I do not even get SMS about missed call. The calling party hears "busy" signal. Edited November 9, 2020 by fashion_m 1 Quote Link to post Share on other sites
D1ggs 141 Posted November 9, 2020 Share Posted November 9, 2020 7 hours ago, fashion_m said: Hi, I use Fxtec Pro1 with the Bulgarian mobile operator Vivacom. "VoLTE provisioned" switch is grayed-out and turned off. I called the support and they told me that VoLTE is enabled for a whitelisted set of popular phones only. The guy sent a message to the technical team about my phone, but it's not guaranteed that Pro1 will be whitelisted neither I'll be contacted at all. I am in areas of bad coverage and the phone frequently switches from 4G to 3G/2G and my internet becomes slow, so I explicitly set network mode to LTE, because weak LTE signal delivers faster internet than 3G with better signal. The bad thing is that I cannot make and receive calls, and I do not even get SMS about missed call. The calling party hears "busy" signal. Very annoying, just to ask are you running the latest version of stock? First i've heard of a GSM carrier whitelisting popular phones for VOLTE. If you are, I would suggest getting root and trying to enable VOLTE using the various patches out there. Quote Link to post Share on other sites
EskeRahn 5,596 Posted November 9, 2020 Author Share Posted November 9, 2020 47 minutes ago, D1ggs said: First i've heard of a GSM carrier whitelisting popular phones for VOLTE. Same situation in Denmark. At the least with "Oister". Quote Link to post Share on other sites
