EskeRahn 5,598 Posted August 4, 2020 Share Posted August 4, 2020 11 hours ago, rubleaj said: Alright more updates because I kind of find this fascinating (though I do not understand it): 1) Phone does not connect to home network (2.4 or 5), WPA2-PSK [AES] (with an alphanumeric password for all examples) 2) Phone does connect to home network (2.4 and 5) with BOTH WPA-PSK [TKIP] + WPA2-PSK [AES] 3) Phone does connect to an unprotected network (2.4 and 5) Hopefully this detail can enable someone smarter than I to figure out exactly what is going on in the background. I tried to change my WiFi from "WPA/WPA2-PSK" to "WPA2-PSK" on my HuaWei B525s-23a. And both a Pro1 on Stock and LineageOS connects to it just fine. Could you give the model number of the netgear router, maybe that can help chasing down the bug. 🙂 Quote Link to post Share on other sites
D1ggs 141 Posted August 4, 2020 Share Posted August 4, 2020 4 hours ago, rubleaj said: I do not have a hotspot, however I could pay for it to test it out (which I may do). As for 5g and 2.4ghz, I have both enabled and tried them both to no avail. Specifically, what I meant is that if you have 2 wireless networks appearing like this: HomeWifi HomeWifi-5g Go into your router settings and switch it so there's one SSID for both your 2.4 and 5ghz networks. Next set up your password as just WPA2-AES. Don't let it include WPA. If you want a good router, I second the Archer C7. Super cheap, great specs, and well supported Quote Link to post Share on other sites
rubleaj 53 Posted August 5, 2020 Author Share Posted August 5, 2020 3 hours ago, D1ggs said: Specifically, what I meant is that if you have 2 wireless networks appearing like this: HomeWifi HomeWifi-5g Go into your router settings and switch it so there's one SSID for both your 2.4 and 5ghz networks. Next set up your password as just WPA2-AES. Don't let it include WPA. If you want a good router, I second the Archer C7. Super cheap, great specs, and well supported Yes I understood you and tried the 2.4 separate from the 5 (sorry if I didn't sound like that). As for the security on my netgear router/modem, the ones I had listed in the previous comment were the only options available. 1 1 Quote Link to post Share on other sites
agent008 248 Posted August 8, 2020 Share Posted August 8, 2020 (edited) I can confirm this solved Pro1 with LineageOS 16 not connecting to a wifi network. In my case router is a MikroTik RouterBOARD 951Ui-2HnD. Not using the stock firmware, i got it with OpenWrt already flashed into it. Edited August 8, 2020 by agent008 Quote Link to post Share on other sites
