kashif 350 Posted August 15, 2020 Share Posted August 15, 2020 Hi Guys Just want to ask, i recently bought another pro1 from a user It doesnt have the sticker on the back, so firstly i dont know serial number\ secondly what implications it would have? thanks Quote Link to post Share on other sites
Jacob_S 128 Posted August 15, 2020 Share Posted August 15, 2020 The serial number should also be on the sticker on the back of the box, have you looked there? Quote Link to post Share on other sites
Hook 3,317 Posted August 15, 2020 Share Posted August 15, 2020 (edited) 16 minutes ago, Jacob_S said: The serial number should also be on the sticker on the back of the box, have you looked there? Nope, no S/N number on the box. There is a serial number on the device, though it isn't the same as on the sticker. The sticker serial number is actually a number that identifies either what sequence the device is in manufacturing or in assignment to shipping. There is no consequence of not having it that I can tell and curiously, I have been told F(x) Tec has no means of retrieving that number. I asked. Which means they make no record of device numbers and who they are assigned to. I don't believe you need that number for any warranty issues. I don't have mine-- it wore off before I realized it would wear off and I didn't record it. 😄 Which is why I asked them if they could retrieve it. Edited August 15, 2020 by Hook 2 3 Quote Link to post Share on other sites
MickH 212 Posted August 16, 2020 Share Posted August 16, 2020 Just a quick tip for anyone in future. If you go to Settings -> About Phone and tap "Device Name" it allows you to edit that text so you could tag the serial No. onto the end of the device name. 2 Quote Link to post Share on other sites
