unknown_death 6 Posted September 22, 2022 Share Posted September 22, 2022 Hey everyone, I am looking to buy a broken Fxtec pro1 to use as parts of you have one please let me know. Quote Link to post Share on other sites
VaZso 1,999 Posted September 22, 2022 Share Posted September 22, 2022 2 hours ago, unknown_death said: Hey everyone, I am looking to buy a broken Fxtec pro1 to use as parts of you have one please let me know. What is the problem of your Pro1? F(x)tec also seems to have some spare parts. Quote Link to post Share on other sites
EskeRahn 5,604 Posted September 22, 2022 Share Posted September 22, 2022 2 hours ago, unknown_death said: Hey everyone, I am looking to buy a broken Fxtec pro1 to use as parts of you have one please let me know. I have had the same thought. Could be nice to have a donor or two at hand if something breaks down in my daily driver. (That was working on the donor) 1 Quote Link to post Share on other sites
unknown_death 6 Posted September 23, 2022 Author Share Posted September 23, 2022 Recently my 18 hours ago, VaZso said: What is the problem of your Pro1? F(x)tec also seems to have some spare parts. Recently my Pro1's finger print sensor started overheating and burns to the touch and is draining my battery quite significantly Quote Link to post Share on other sites
VaZso 1,999 Posted September 23, 2022 Share Posted September 23, 2022 43 minutes ago, unknown_death said: Recently my Recently my Pro1's finger print sensor started overheating and burns to the touch and is draining my battery quite significantly I think it is harder to obtain that part but it worth a try to ask if F(x)tec has spare items. Otherwise, I would pull the ribbon cable of the sensor - that way the phone itself would remain usable without excessive battery drain. However, it needs opening the bottom part of the phone - the worst part of assembling/disassembling of the phone is the ribbon cable of fingerprint sensor anyway as that is the cable what users can easily break in case the lack of attention. 2 Quote Link to post Share on other sites
Rob. S. 1,667 Posted September 23, 2022 Share Posted September 23, 2022 1 hour ago, VaZso said: 2 hours ago, unknown_death said: Recently my Pro1's finger print sensor started overheating and burns to the touch and is draining my battery quite significantly I think it is harder to obtain that part but it worth a try to ask if F(x)tec has spare items. Unfortunately I can report that they didn't have any when I asked, which was just recently. Those sensors indeed seem to be difficult to source, all the more so since the Pro1X now uses a different one. 2 Quote Link to post Share on other sites
unknown_death 6 Posted September 23, 2022 Author Share Posted September 23, 2022 I also asked to see if they have the entire backpanel as a replacement part. Though the finger print sensor in the pro1x is different I dont see why it wouldnt work in the other phone as the connectors are the same Quote Link to post Share on other sites
