Juanjeste 4 Posted December 19, 2023 Share Posted December 19, 2023 Hello, can someone help me why I connect my Pro1-X with Android to Windows 11 and it doesn't recognize it. I have tried installing different drivers but it still doesn't work. Quote Link to post Share on other sites
Hook 3,316 Posted December 19, 2023 Share Posted December 19, 2023 Need a bit more information. Are you connecting just to access files from your computer or are you trying to do things with fastboot and ADB commands to flash an alternative OS or root. Have you tried different USB ports on your computer? Have you tried different cables, making sure they are data cables and not just for charging? If just transfering files, have you made sure, once connected to the computer that you change the default "charge only" setting to "file transfer?" There is a notification in the pull down shade that you tap to make this change. 1 1 Quote Link to post Share on other sites
Juanjeste 4 Posted December 19, 2023 Author Share Posted December 19, 2023 It is mainly for file exchange between Pro1-X and windows. All of this has been tried several times but it doesn't work. All Windows drivers are up to date. I don't know what else I can try. any suggestions? Quote Link to post Share on other sites
EskeRahn 5,598 Posted December 19, 2023 Share Posted December 19, 2023 Have you got a USB-hub? Maybe your monitor has a usb in and some usb out? If so try to connect that way. It sounds crazy but it is often easier to get it to work with a slower port than the fast ports in a modern PC. I got a fairly new Lenovo Yoga, and things does not work connected directly. But I use a Lenovo thundebolt 4 hub for two secondary 4K monitors and other, and if I attach the cable to that, things work. And both the pc and hub's ports are usb 3.0 2 1 Quote Link to post Share on other sites
CornholioGSM 370 Posted December 20, 2023 Share Posted December 20, 2023 Check hardware manager...is Pro1 detected after connecting as any device or unknown device? Do you hear connection sound? Phone must be detected on any connection profile mtp,ptp etc etc....and because it is android device then w10/11 have all drivers preinstalled for connect booted android phone. Another situation will be with adb drivers but it is not your problem. Soo if you dont see any device in hw manager, then it is problem with usbc connector or cable. 2 1 Quote Link to post Share on other sites
Juanjeste 4 Posted December 21, 2023 Author Share Posted December 21, 2023 I already checked device manager but it does not detect Pr01-X, but it does make the connection sound and it also sounds when you change profiles. I have tried several USB connectors and various cables. 1 Quote Link to post Share on other sites
Juanjeste 4 Posted December 21, 2023 Author Share Posted December 21, 2023 After messing around with ADB and in debugging mode I have managed to get Windows to detect Pro1-X but only in ptp mode so I can only transfer photographs, I will continue investigating. Thank you all. 2 Quote Link to post Share on other sites
sequestris 710 Posted January 11, 2024 Share Posted January 11, 2024 You have to go into Connected Devices and select USB and the select File Transfer Quote Link to post Share on other sites
